Brewing ratios for espresso beverages - Page 2
Link to "Brewing ratios for espresso beverages"by AndyS on Mon Nov 13, 2006 9:32 pm
Psyd wrote:I think that the terms are liberally (and somewhat glibly) applied, too, but I think that that evolved from baristas trying new things and needing some new terms to describe how they were arriving at their results. "Hey, How'd you do that! ?!" "I just overfilled the basket till it restricted the flow a bit more and took a bit longer to pull the shot."
"Hey, use Franco's 'restricted' technique, it's great."
"What's this? It's good!"
"That's a 'restricted' shot."
"Hey, make me one of those 'restricted' shots'"
"Franco, another 'restricted', please"
That is no problem if you're in Franco's bar. It IS a problem if Franco is in Italy and you're in Tucson. Not only is it a pain in the ass, but the resulting confusion is stifling the development of the espresso culinary art. IMHO.
-AndyS
Schectermatic, the oldest, most trusted brand of espresso grinder shnozzola
AndyS
Link to "Brewing ratios for espresso beverages"by AndyS on Mon Nov 13, 2006 9:37 pm
RapidCoffee wrote:But flow rates/shot timings really ought to be part of the definitions, not just brew ratios.
In general, I prefer regular espressos at 25-30 secs. For ristrettos I often go a few seconds more. That's about all I can say. How about you?
-AndyS
AndyS
www.swisscoffeeproducts.com: espresso, the chemistry of love
Link to "Brewing ratios for espresso beverages"by RapidCoffee on Mon Nov 13, 2006 10:26 pm
AndyS wrote:In general, I prefer regular espressos at 25-30 secs. For ristrettos I often go a few seconds more. That's about all I can say. How about you?
That sounds about right. And lungos (which I don't make, at least not intentionally :)), a few seconds less.
Again, no intent to hijack this discussion away from brew ratios. Thanks for taking the time to put the chart together.
________
John
RapidCoffee
Link to "Brewing ratios for espresso beverages"by cannonfodder on Tue Nov 14, 2006 5:09 pm
When I make a ristretto, I keep the same timing I normally use for a 'standard' double but reduce the normal volume depending on the coffee. So if blend x works best with an 18 gram dose, 28 second extract at 1.75oz, my ristretto would be (in general terms) 18 gram dose, 28 second extract at 1-1.25 oz as a general guideline. Then adjust based on taste.
cannonfodder
Link to "Brewing ratios for espresso beverages"by Psyd on Tue Nov 14, 2006 6:25 pm
AndyS wrote:That is no problem if you're in Franco's bar. It IS a problem if Franco is in Italy and you're in Tucson. Not only is it a pain in the ass, but the resulting confusion is stifling the development of the espresso culinary art. IMHO.
I meant that conversation as to how the term got started (purely artist's conjecture, mind you...) not as what the term is supposed to mean. It is very probable that this is very similar to the actual birth of a ristretto, though, as this is how things do. So, a ristretto, in this theoretical example, would be the technique that Franco stumbled upon or rushed into, not a given extraction or something 'other than an espresso' but a variation in technique. By using the technique, instead of the result, I can get instructions from Franco over the phone as to how he came up with this new wonderful thing, and it requires no new gadget, kit, or chart.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "Brewing ratios for espresso beverages"by HB on Sat Dec 16, 2006 10:30 pm
When I can remember, I've been measuring the weight and approximating the volume of my daily espressos. Sorry, I didn't write down the figures, but I can offer from memory some general observations.
The majority of the extractions fell in the low-high range of 17-20 dry coffee grams / 17-25 beverage grams / 1.3-1.6 ounces (including crema). Although all of the espressos were below two ounces, the 22+ beverage grams drinks had the profile evoking my definition of a "true double" and those at 17 grams and below had distinct ristretto-esque characteristics.
One lesson I learned from weighing: The weight of the espresso correlates more readily with the flavor profile than the final volume. Lately I've been thinking about how to combine the actual beverage weight and Al's Rule. It may be a bit extreme to pull the espresso with the cup sitting on a 0.1 accuracy gram scale and the timer going... but I'm tempted.
andyS wrote:Image
(Click above to see larger image)
Link to "Brewing ratios for espresso beverages"by AndyS on Sun Dec 17, 2006 12:51 am
HB wrote:When I can remember, I've been measuring the weight and approximating the volume of my daily espressos. Sorry, I didn't write down the figures, but I can offer from memory some general observations.
Dan, you're the only one who's given me any data at all. Thanks!
HB wrote:The majority of the extractions fell in the low-high range of 17-20 dry coffee grams / 17-25 beverage grams / 1.3-1.6 ounces (including crema). Although all of the espressos were below two ounces, the 22+ beverage grams drinks had the profile evoking my definition of a "true double" and those at 17 grams and below had distinct ristretto-esque characteristics.
So here's how I see your data:
Average dose is 18.5 grams
18.5 gram dose / 22 gram beverage = 84% brewing ratio
18.5 gram dose / 17 gram beverage = 106% brewing ratio
In contrast, lately I've been brewing shots like this:
15 gram dose / 30 gram beverage = 50% brewing ratio
My shots are obviously less concentrated (less ristretto) than yours. To me, they taste and feel like "traditional doubles."
But aside from mere semantics, this is what is interesting to me: even though we're starting with different doses, we can make reasonably accurate comparisons between your shots and mine to compare flavors. Tomorrow I'll try some shots using my dose (15 grams) and your 84% brewing ratio (which should yield ~18 gram beverages) and see if they begin to taste like "traditional doubles."
HB wrote:One lesson I learned from weighing: The weight of the espresso correlates more readily with the flavor profile than the final volume.
Then you really get what I'm trying to say...although since the dose can change, I'd be REALLY tickled if you said "the brewing ratio correlates more readily with the flavor profile than the final volume."
HB wrote:Lately I've been thinking about how to combine the actual beverage weight and Al's Rule. It may be a bit extreme to pull the espresso with the cup sitting on a 0.1 accuracy gram scale and the timer going... but I'm tempted.
Yeah, that's EXTREME, all right. Of course on an automatic machine, beverage weight is fairly reproducible. So you can get very close to a given target weight without the absurdity of having to pull with the cup on a scale. The automatic allows you to geek out while still maintaining self-respect. ;-)
-AndyS
AndyS
Link to "Brewing ratios for espresso beverages"by HB on Sun Dec 17, 2006 1:16 am
AndyS wrote:So here's how I see your data:
You're right, my lowest brewing ratio espressos were in the 60% range. Those that were lower lacked the dense crema and heavy body I like, though some were still quite enjoyable. An espresso blend like Black Cat, for example, showed its stuff in the 100% range and became less interesting in the 50% range. More citrusy Northern Italian blends like Dark Star from Rocket Coffee (which despite its name is actually medium roasted) appealed to me around a 60% brewing ratio.
Thanks Andy for the idea. While we may quibble about the definition of a "true double," at least we have a way of accurately speaking about the brew concentration that others can reproduce. It's easy to be "fooled" into producing a ristretto because of high crema production. Not that there's anything wrong with that, but by volume, an espresso may look like a double when in fact it's a ristretto in crema's clothing.
AndyS wrote:Of course on an automatic machine, beverage weight is fairly reproducible. So you can get very close to a given target weight without the absurdity of having to pull with the cup on a scale. The automatic allows you to geek out while still maintaining self-respect. ;-)
Funny how I never thought of using volumetric dosing for that... you know, dosing the volume. I always thought of them as "inattention safety devices." :roll:
Link to "Brewing ratios for espresso beverages"by AndyS on Sun Dec 17, 2006 11:14 pm
HB wrote: While we may quibble about the definition of a "true double," at least we have a way of accurately speaking about the brew concentration that others can reproduce. It's easy to be "fooled" into producing a ristretto because of high crema production.
Exactly!
Today I pulled shots at various brewing ratios using my homeroasted coffee. I find I have to get pretty close to a 50% brew ratio (15g dry yielding 30g wet) before it feels like a "traditional double" to me. But then there's not much latitude: I can't pull the shots much higher in volume before they get way too thin and flabby.
Again, it's not about drawing a line in the sand that separates a "true espresso" from a "true ristretto." That will always remain a matter of taste (although some generally accepted guidelines might be helpful).
What this brewing ratio thing is about is understanding and communicating the parameters that we use to produce the shots we like.
-AndyS
AndyS
Link to "Brewing ratios for espresso beverages"by alsterlingcafe on Tue Dec 19, 2006 11:56 pm
Andy, thanks for sharing the chart. Although an obsessive hobbiest in whatever area of interest I find myself, with espresso I've come to look for references along the way; essentially starting points. With food and beverage for instance, and to a lesser degree baking, the phrase "....season to taste" always comes to mind. It gives me license to experiment. But before the experimentation, I need a starting point. You've really done a nice job here.
Your chart posting got me to think about a recent visit to an espresso cafe in Washington state. On a recent trip to Seattle I visited with David Schomer at his new Yale St. espresso cafe. On the menu board, at the top under CAPPUCCINOS, they have written, and I'll paraphrase here...... ALL CAPPUCCINOS ARE RISTRETTO MACHIATTOS. I should call them up again and have them clarify that for me. But what I can tell you is that after that trip a few months back, and tasting their RM, I came home with validation that my slow migration to shortening my shots before the blonding, and reducing my milk and foam even more, was essentially what David Schomer had done! Understand that I started out a year ago using "The Golden Rule" as distributed by Wholelattelove. Again, it was a starting point. As soon as I get my espresso bar setup again here at the new place, I'm going to take your chart, which I've printed and laminated, and see how it "quantitatively" parallels what I've been doing.
I travel quite a bit on business, and in what time I can sneak in, visit any coffee related suppliers, wholesalers, repair shops and retailers. What I've found is that save for some industry types, a few Third Wave espresso cafes and trained barista-types in the US and around the world, there's a shockingly few people, even in the espresso business, that have an understanding of specialty coffee, or coffee in general. (I never assume someone I'm speaking with understands that Juan Valdez doesn't ship roasted and ground coffee to the US for packaging in cans that make a sucking sound when you open them!?)
Again, this may seem obsessive to some, but if placed within the context of an overall learning package, I think it's a vital learning tool and reference. I'd like to see your chart applied in a training video; maybe picking 3 to 5 drink combinations? With video posting becoming more and more popular, your chart could make for a great advanced training element.
Best, Al
-------------My Growing Espresso Video Collection from Brasil---------
Espresso Cafes of Brasil, Santo Grao, Sao Paulo
Espresso Cafes of Brasil, Suplicy-Jardins District, Sao Paulo
Cupping Coffee in Sul de Minas at a Coffee Cooperative Lab
La Spaziale S1 temporary setup
alsterlingcafe
Link to "Brewing ratios for espresso beverages"by erics on Thu Dec 21, 2006 5:13 pm
Hi Andy - great idea
"Double-Espresso"
18 grams of coffee, 48.5 grams total beverage weight (before milk of course).
Eric S.
erics
Link to "Brewing ratios for espresso beverages"by jesawdy on Thu Dec 21, 2006 5:26 pm
erics wrote:"Double-Espresso"
Well the idea is to also report the brewing ratio - 37% in this case :)
Jeff Sawdy
jesawdy
Link to "Brewing ratios for espresso beverages"by AndyS on Thu Dec 21, 2006 11:37 pm
erics wrote:Hi Andy - great idea
"Double-Espresso"
Thanks, Eric.
That's a pretty long shot! I think it takes skill to pull that big a shot without getting watery at the end.
-AndyS
AndyS
Link to "Brewing ratios for espresso beverages"by jesawdy on Fri Dec 22, 2006 10:26 am
Well, it is only one data point, and I want to play with this some more...
On Silvia, this AM, 20.1g (in a 14g ridgeless, can you say overdosed :shock:, coffee came up to showerscreen, no headspace), beverage weight 40.4g, equals brew ratio of 49.8%.
Just by visual observation and feel, this was not my typical morning shot on Silvia... my guess is that I am more typically at 17-18g of coffee and just slightly more volume. That may but me closer to to erics's 37%.
Unfortunately, I didn't have time to pull another.
Jeff Sawdy
jesawdy
Link to "Brewing ratios for espresso beverages"by erics on Fri Dec 22, 2006 11:33 am
Here is what I think to be an interesting little tidbit. Every once in a while I will stray from my usual bean and buy something special - like a few weeks ago I bought some of the SERBC beans from Murky - nice treat. Anyway, MM electronic (timed running) dosed those grinds out 10-12% above normal dosage weight.
My normal procedure is to use 18 g (weighed) of beans and tamp in a LM ridgeless basket with Silvia. I do think I tend to run a little blonder than most (at least from what I've read) but I'm happy with the product. I make the same drink all the time (yea I know,boring, but good) and will average a weeks worth and send that in now that I've discovered that my one and only cappy cup won't overload the scale (242.5 g's).
Eric
erics
Link to "Brewing ratios for espresso beverages"by AndyS on Fri Dec 22, 2006 7:25 pm
jesawdy wrote:On Silvia, this AM, 20.1g (in a 14g ridgeless, can you say overdosed :shock:, coffee came up to showerscreen, no headspace), beverage weight 40.4g, equals brew ratio of 49.8%.
I play around all he time, but lately I've pulled a bunch with 16g coffee and 28-32g beverage: brewing ratios of 50%-57%. Seems to give the flavors more room to "breathe" compared to ristretto pulls, but the coffee is still reasonably sweet and heavy in body.
-AndyS
AndyS
Link to "Brewing ratios for espresso beverages"by jesawdy on Wed Dec 27, 2006 5:23 pm
Okay, I have a few more datapoints... with Paradise Roasters Espresso Classico, Silvia, and an "LM" ridgeless 14 gram basket I pulled the following over the last few days (when I could be bothered to weigh stuff :D)
grams coffee / grams beverage / brew ratio
19.5 / 43.3 / 45.0%
20.6 / 58.1 / 35.5%
20.3 / 33.3 / 61.0%
19.9 / 46.3 / 43.0%
19.1 / 38.9 / 49.1%
19.0 / 42.3 / 44.9%
19.0 / 38.0 / 50.0%
20.1 / 38.0 / 52.9%
20.3 / 41.4 / 49.0%
In doing this process, I was surprised by two things: First I was using more coffee than I would've thought (I dose by volume to basket edge now), and second that my beverages weigh less than I would've initially guessed. With an average of 47.8%, I am clearly in the middle of your double espresso range of 40-60% with two outlying shots... the 35.5% shot I ran long because it was a slow pouring shot to start, the 61% I'm not sure what my deal was.
I was also pretty happy with my dosing consistency, a level distrubution to the basket edge was ~20g, and a slightly less than full basket was ~19g in this case.
I will be curious to see if things change with a new blend... I finished up the PR Espresso Classico this AM. I am thinking that as light at this roast is, the bean density is higher than a lot of other blends I typically use.
Jeff Sawdy
jesawdy
Link to "Brewing ratios for espresso beverages"by jesawdy on Fri Dec 29, 2006 5:03 pm
Nothing fancy or earth shattering, but this is what I am using to take my brew and tasting notes right now while I play with AndyS's idea.
brew_ratio_log.pdf
I use the Notes section to record temp, grind, tasting notes, problems, ideas, etc.
Jeff Sawdy
jesawdy
Link to "Brewing ratios for espresso beverages"by tmaynard on Fri Dec 29, 2006 10:55 pm
jesawdy wrote:Nothing fancy or earth shattering, but this is what I am using to take my brew and tasting notes right now while I play with AndyS's idea
I'm tempted to convert your PDF to an Excel (Open Office) spreadsheet, where the calculations (only a couple) are done for you as you enter the data -- I've always been a lazy-smart-a*s. It just seems like the next logical step upward. Why fetch your calculator when the machine you're typing on can do the math for you?
Just a thought.
t++
tmaynard
Link to "Brewing ratios for espresso beverages"by AndyS on Sun Dec 31, 2006 11:58 pm
Jeff, thanks for taking the time to record the data.
It is interesting what you may find when you start to measure and compare. 19-20 grams of coffee in a 14 gram basket! So much for "nominal" basket dosing.
I would agree that your shots are smack in the middle of the traditional espresso range. These are much "longer" shots than the ones I sampled recently at high-end cafes in NYC. Not that anyone there weighs their shots!
-AndyS
AndyS
PreviousNext
Return to Tips and Techniques
