Gismar wrote: ... when I dose this at 60 grams pr liter water, compared to other darker roasts, I have to either updose the amount of coffee or adjust my grinder to a finer grind.
Why do you have to do this?
I see two possibilities, and neither requires changing the way you brew
First, you may be unfamiliar with the taste and balance of light roasted coffees. These are about crisp acidity and light sugars, not heavy caramels and roasty distillates. Grinding finer will just get you a dull and bitter tasting over extracted mess; up-dosing will get you more acids and sugars; but neither will get you more roast flavors. Expect the coffee to taste a lot more tea or white wine like.
Second, you may be unfamiliar with how to roast light. If the coffee tastes grassy and vegetal, or like swimming pool chlorine, or overbearingly tannic, then you messed up the roast. If so, no brewing tricks will help, and no amount of habituation will make it taste better. Roasting light is much harder than roasting dark; so your first few dozen light roasts are quite likely to be poor. The best learning strategy is roast just slightly lighter at each step, while keeping the length of the roast from the start of the first crack to the end of the roast about the same length, no matter how light you roast (i.e. reduce the heat more drastically just ahead of the first crack for light roasts than for dark roasts). By keeping the roast timing the same, you will ensure the elimination of grassy and other raw flavors, and also achieve a familiar and tasty balance of sugars to acids.
