Brew pressure profiling using the steam wand?
Postby Arpi on Fri Oct 14, 2011 4:30 pm
Hi.
I have a Gaggia Classic (single boiler) and it seems that the pressure can be gradually dropped (but not sure how much) during the shot by opening the steam wand. I use a Hario V60 Kettle and then the exiting water from the wand can then be reused. The temperature will probably also dropped since the boiler in this machine is small but it looks like an easy way to maybe do "pressure profiling." I was thinking that maybe in a E61 brew head, a butterfly valve maybe could be added in the same fashion or maybe tapped in another point of the system (before the hot brew boiler).
I tried and it does something but it is just an idea.
Cheers
Arpi
Postby cafeIKE on Fri Oct 14, 2011 6:46 pm
cafeIKE
Postby HB on Fri Oct 14, 2011 7:50 pm
Rancilio Silvia Preinfusion Technique takes the same approach. The main benefit of a slower brew pressure increase is the improved "forgiveness factor". It may be worth the trouble for Silvia, but in my experience, the Gaggia Classic is already tolerant of minor errors in barista technique. That said, it's worth trying, assuming the technique doesn't crater the brew temperature.
Postby Arpi on Sat Oct 15, 2011 9:49 am
Thanks for the links.
I was thinking that if the valve was located before the boiler (cold side), and the released water was exiting to the inlet, then the temperature would not drop during the shot. So maybe an extra knob (like the steam wand knob) could be added to control the pressure by using a bypass valve.
Cheers
Arpi
Postby hbuchtel on Tue Oct 18, 2011 9:44 pm
I can confirm that putting the valve on the cold water side of the boiler does work, quite well in fact. I used a needle valve (I think that is what it is called) that allowed very good control over the brew pressure.
Here is a video of a 'spring lever' type of pressure profile, i.e. 9 bar at the beginning and then falling off as the shot progresses: 9 Bar then falling
LMWDP #53
hbuchtel
Return to Tips and Techniques
