As of recent I've started to play with the 16gr basket in my open portafilter on my Dalla Corte Mini.
but I am not sure what exactly is going wrong...
if I grind too fine (by little) the coffee almost won't come through... it only will dribble randomly at certain spots beneath the basket...
if I set it little coarser coffee flow seems fine, but the extraction is uneven... resulting in two or three "exit points" at the basket and it usually Sputters water/coffee all around... making a mess.
the coffee is "Ok" - read "not great, but drinkable (it could be much better)".
The one thing which annoys me most is that I started to play with the bottom less p/f when I started not to get the desired crema anymore... (don't know if it's my new coffee... or something with the machine (doubt it)).... so I thought the bottom less p/f would be a good way to check what's happening,... and the results are described above.
now I've tried a lot... but the results are far from consistent.
I also checked the brewing pressure inside the p/f using a special porta-filter pressure gauge I built (0-15bar gauge on a 3/8 T-Elbow)... and the dalla corte is dialed in at 9,8-10 bar) (which seems fine imho).
Temperature is very consistent set to 95°C (so I guess I've got the basics still right).
One thing I was wondering if water hardness and resulting scale could have some influence... I'm trying a different type of water at the moment...
any tips and hints VERY welcome
thanks
