by David 23 on Tue Aug 25, 2009 11:32 pm
Ok, humor me, I have been wondering about portafilters, and how they might (?) alter and affect extractions.
Sometimes a bottomless PF, if everything is not perfect, will dribble and then pour in more than one little stream, and not evenly from the entire bottom of the PF, which is not really desirable. If one gets a little probe, and touches the streams you can bring them together to form a nice single stream and more even "pulling" from all around the PF bottom, rather than just a couple areas. When using a spouted PF, you can't see whether the extraction is coming out in one nice stream for several. However, I wonder if the shape of a spouted PF, allows enough fluid to "back up " slightly, and pull any potenial mulitiple streams into one single, more even extraction, thus in effect, making a better pull from the entire surface area of the basket bottom.
I'm not suggesting this as a remedy or crutch, just wondering about the dynamics. What do you think?
