BMF600XL Breville Milk Frother - Set it and forget it
I've come to prefer the Breville BMF600XL Milk Cafe over my steam wand. It heats the milk perfectly to just under 160 deg every time, when set at max. 2% froths too much, 1% too little. By mixing the two in equal amounts (which I do in a 1/2 gallon jug) beforehand, I am getting just swell froth that gives me microfoam mouthfeel. It always heats to 158 F on the button; so consistent and simple. ~5 oz of milk takes 2 min. or so, the time it takes for me to grind, tamp and pull. I no longer have to nurse my foam for lattes standing by the wand. If I set the temperature lower, like to 145 deg., I get less froth, because it shuts off earlier. I find 4-5 ounces of 50:50 2%/1% gives me the best foam for latte; the foam does not collapse over time. No skills needed, which some might see as a plus. Also, I read that it makes incomparable hot chocolate.
I also tried the Sherwood SMF-1000P. It's a good unit that has unique design features and some advantages over the Breville. Mainly, it froths 1% milk pretty well, but interestingly, it depends on the milk. Brands froth differently. It's capacity is much lower, but sufficient for a single latte serving. Overall, the Breville is the winner, tops the entire market in frothing. It should be because it's the most expensive. For someone that uses a moka pot, either of these frothers might make for a relatively inexpensive worthy combo. Not for me; just saying.
My Quickmill Carola and Breville BMF600XL make a nice combo that has far exceeded my expectations, with respect to the latter. Not saying a frother beats a prosumer steam wand, only that I've come to like the frothing approach a lot, even though I have access to a steam wand on another machine. That surprised me in the end.
Someone sent me this reply as a PM. He doubts, saying:
"I'm suggesting it's incapable of making microfoam suitable for a proper latte that requires homogenous microfoam."
I don't blame him for doubt.
I had doubts these videos were true, thinking they were shilling. I was very surprised, just like the folks in the video, with the output quality of this frother. I love it with my Carola.
https://www.youtube.com/watch?v=YsB-pCm5Cm8
https://www.youtube.com/watch?v=St-_9nSp320
https://www.youtube.com/watch?v=4jJPjZFDxII
https://www.youtube.com/watch?v=TAoyl28lU4M
Has anyone actually tried this BMF600XL machine, specifically?
I have one on order.
We use a cheap Casa frother we bought on sale at Bed Bath and Beyond on sale for $40 and we love it - because I am on a low carb high fat diet we stay away from the sugar in milk by frothing:
Grass fed butter
MCT oil
Heavy cream
Fairlife reduced carb whole milk
Kroger Carbmaster milk
I want to try the Breville for two reasons:
1) better temperature control
2) capacity to froth enough for two drinks at once
Ps - we are pleased with the texture created by the Casa and the above mixture
I'll report back once we get the Breville
Grass fed butter
MCT oil
Heavy cream
I have a Severin SM9688 which looks functionally identical to the Breville. (Unusually in this day of badge engineering they appear to be independent brands; no doubt the frothers come from the same Chinese factory.)
It works OK as a frother if you don't expect too much, but it does not produce good quality microfoam. Immediately after frothing you will have a mass of froth with no liquid content which is useless for adding to coffee. If you wait a minute or two some of the froth collapses and you can successfully pour it into a coffee and produce what passes for a cappuccino in many cafes.
I bought mine to use with an EspressoForge when the normal machine wasn't on. It's just about acceptable but doesn't produce milk with anything approaching the quality of steam foamed milk; your PMer was quite correct.
Clearly, the BMF600XL is a step up from a hand held, which you recognize. But, the cost of a hand held is ridiculously low. That's the main virtue. My guess is that hot milk froths poorly, and mic-ing frothed milk destroys microfoam, I find. So, handhelds seem not to be a solution for latte, I'm thinking.
As for Severin, it does seem to be just like the Breville. Thanks for pointing that out.
I avoid the mass of foam on top that you mention with two solutions. 1) can't let the milk sit after the ready beep for more than 20-30 secs. Swirling the jug gets the 'blob' nicely incorporated into 'microfoam', but only if done quite soon after the beep; the sooner the better. Better not to have the blob to start with; I avoid by not letting the milk sit for more than 20 secs or so. 2) If I use 2% only, the froth is too much; great for caps, not lattes. 1% gives little foam, and different brands of 1% yield different quality and quantity of foam. A 50:50 or so mix of 1% and 2% works well for me, and I mix 1 quart with another in a half gallon jug. Varying temperature also has an impact, because this affects the time the unit will froth for, of course.
All the above is with the Cap disk; I find the Latte disk not good at all, for me, with neither 2% nor 1%.
Thanks again for replies. I hope some of the info might be useful to some. I find this site fabulous for ideas and direction!
