www.baratza.com: skilled in the art of grinding
Blob of foam in the center of the pitcher
Postby avdiscolo on Tue Oct 02, 2007 12:16 pm
Sometimes when I am spinning the milk in my pitcher to create microfoam, a thicker blob of foam settles in the center of the pitcher, and I cannot seem to break it up with gentle spinning and tapping of the pitcher after steaming. I'm happy with the density of the rest of the microfoam, but the blob is preventing me from attempting any latte art.
Any help would be greatly appreciated.
Thanks,
Anthony
avdiscolo
Postby Beezer on Tue Oct 02, 2007 12:32 pm
You can scoop it out with a spoon, or try pouring it out into the sink before pouring your art. That's what I usually do if I get the dreaded "cotton ball" in my pitcher.
Lock and load!
Beezer
Postby HB on Tue Oct 02, 2007 1:07 pm
The cotton ball occurs when you inject too much air. Avoid playing the tip across the surface of the milk, shorten the stretching phase, and lengthen the texturing phase (e.g., instead of burying the tip at 100F, try 80F). If you get cotton foam anyway, it can be remixed with aggressive swirling. It's helpful to have a larger pitcher for this purpose so you whirlpool higher up the sides. I demonstrated this recovery move in Latte Art Challenge(d):
Postby RegulatorJohnson on Tue Oct 02, 2007 1:08 pm
experiment with angles and such to create a vigorous folding type of swirl while you steam. perhaps even with water to see what angle creates the most powerful swirl. then switch to milk.
jon
jon stovall
coffeetoolsapp.com
RegulatorJohnson
Return to Tips and Techniques
