shadowfax wrote:As a longtime proponent of freezing, it pains me to say this a little, but here it is. I guess it's not surprising, and as always YMMV.
I store my coffee in carefully sealed mason jars. I believe they are the half pint jars—they hold about 1/3 lbs. of coffee. I'm short on real estate here (please, restrain your laughter for a minute), so I don't have a deep freezer at the moment, and my coffee goes in the crappy auto-defrosting freezer. This has worked great for me for periods of at least 2 weeks, maybe a bit more.
Earlier this year I got 4 lbs. of CCC Shakisso SOE and I froze the bulk of it about 5 or 6 days out of roast, taking out a jar of it every few days as I was ready for it. This worked great for about a month. As 'bad' luck had it, I ended up sandwiching another coffee in there that spread out my consumption of the Shakisso so that I was finishing it about 6 weeks after I got it. I really noticed that it had gone quite flat right out of the freezer; I was pretty unhappy with it, and it was a poor way to finish my experience with that coffee. I'm definitely going to stick with much shorter-term freezing in the future, given this setup for freezing. I think a cheap deep freeze is in my future.
Hi Nicholas,
I think (not unsurprisingly) that you have two two things working against you in this situation. The first one is that the coffee was already about ready to decline when you froze it (true for most coffees at 6 days post roast, in my experience), and your freezer situation isn't optimal. I think that if the coffee was fresher when you froze it, or you had used a colder freezer (especially not a frost free one), that the coffee would have lasted a lot longer.
I'd advise people to freeze their coffee as soon after roasting as possible, if they want it to last for any period of time. If you are not a home roaster then you can't freeze it as quickly as I can freeze mine, and if freezer preservation is going to be an approach that you use, it would argue for obtaining coffee from nearby sources that won't take too long to get to you (at an affordable shipping cost). The reduction in staling is going to be very much related to freezer temperature, the colder the better. So, use your coldest freezer and adjust your expectations for freezer preservation to whatever type of freezer you are using as this is going to make a real difference.
ken
