by JmanEspresso on Sun Oct 18, 2009 6:39 am
I water backflush, 10sec on/10 sec off, two times, after every shot.
Everytime I backflush, I remove the shower screen and group gasket.
I backflush usually every 7 days, sometimes I push it to 10days If Im lazy.
My routine is pretty similar to yours:
Pallo scoop of Cleaner... Im pretty cautious not to use too much.
Two cycles of pump on 10 seconds, off 10 seconds
Let machine sit for ~20 minutes
2 more cycles, 10 on/10 off
Remove PF, and run pump while rinsing/scrubbing the PF and Shower screen/Gasket. ~15 seconds.
Put PF back in group
10 cycles of just water, 10 on/10 off
Remove PF again, and give a good long rinse and scrub to the screen/gasket
Somewhat cooled from the last step, remove Shower Screen and Gasket
Soak the baskets I used since last flush, all PFs used, Shower Screen, Steam Tip(s), Water Tap Spout in Detergent for ~20 minutes, then scrub, then rinse. Scrub and rinse gasket by hand, I dont soak it for some reason.
Put everything back together
Pull three seasoning/sink shots with old coffee.
Enjoy a nicely cleaned machine.
On backflush day, I also wipe down my entire machine, and use a mild detergent solution and clean all my cups with it, simply by giving them a quick scrub(very quick), and a 5 minute soak in it... Rinse and put back. I wash out my reservoir. I also clean my grinder. Remove doser star, brush clean, remove top burr carrier, and with a brass brush, lightly brush off any coffee from both burrs, without removing them. Give the burr chamber a blast of air, reassemble. I actually remove the burrs every other month, or so.
My detergent of choice is Joe-Glo. Less foam then Cafiza. Ive used and own both, and besides less foam, I dont notice any difference.
. . . I tend to be a bit of a clean freak with my coffee stuff.
