King Seven wrote:On several occasions I've seen people get coffee grounds up in the tube, and that having put the screw back in turn on the group and shoot the grounds into the dispersion screw preventing water leaving the group.
This is a better case scenario because at least the screw can be removed and cleaned out. It could get clogged more permanently quite easily.
James, would I be going out on a limb if I guessed that the people you've witnessed getting grinds up the feed tube when backflushing sans dispersion disk were maybe following a regimen where they simply pulled the screen for a soak and started backflushing without de-gunking the dispersion block (or whatever they call that disk behind the screen on an LM-style machine)? I have no idea if that's a bad idea or not, but I don't see the harm in backflushing screenless and screwless if you've cleared all the big grinds via, for example, a good brushing and flushing with a blind filter loose in the group (wriggling side to side). Indeed, it's been pointed out to me by a
forum member that the GS3 Operating Manual recommends removing the screen and dispersion screw when backflushing:
GS3 Manual wrote:Cleaning (Daily)- Cleaning the Diffuser Screen.
During the discharge operation (subsequent to coffee brewing), small amounts of coffee grounds may slowly build-up on and obstruct, even partially, the diffuser screen. Remove the diffuser screen by unscrewing the diffuser screw. Place 2 or 3 teaspoons of detergent powder for coffee machines in about 1/2 a litre of hot water. Place the diffuser screen and diffuser screw in the solution and leave them fully submerged for about 30 minutes. Rinse thoroughly with clean water. Install and run hot water through the group head several times with the screen installed.
- Cleaning the Brewing System.
Remove the diffuser screen as described in the previous step. Install the blind filter into one of the supplied portafilter handles. Place a tablespoon of detergent powder for coffee machines into the blind filter and install the portafilter into the espresso machine.
Cycle the espresso machine on and off using the continuous button. Cycle approximately 10-20 times. The cycling of the espresso machine allows the detergent powder to flow through the brew system cleaning the components. Remove the portafilter from the espresso machine.
After cleaning, rinse the group head by activating the continuous button or approximately 10 seconds. Using a damp cloth wipe clean the area where the portafilter engages into the group head. Then replace the diffuser screen.
I have to admit I am rather surprised, and indeed I actually find their instructions a bit lacking when it comes to order (wait until after backflushing to wipe the gasket?) and thoroughness of rinsing (just a 10 second flush?). Anyway, I thought it was an interesting point. I'm tempted to think the screen thing is more "no big deal" than a wisdom issue, but that's just my opinion as someone not well-versed in big commercial LMs. I understand LM installed 0.6 mm gicleurs right behind the dispersion screw on some Lineas and FB70s (and maybe others?), which strikes me as the perfect recipe for getting your group clogged up if you're not careful. The devil may be in details of that nature.
