A key to your "problem" or "fortune" would be your specific altitude in
Boulder, CO. See my chart on this page for an interesting read:
How does high altitude affect brewing?For the Rocket line of machines in your particular case, I would say that it is best to flush a few ounces and brew, i.e. you would be following a flush-n-go procedure. This is, by a goodly margin, the most common way of preparing a drink. Backflushing has its place but not here.
Typically I have seen and read that Rocket machines arrive at the doorstep with a maximum boiler pressure reading of 1.10 bar. For the average user, a flush of 5-6 ounces and brew would be fine. But for you in Boulder, CO, a lesser flush would be better because you are starting off at a lower temp due to the altitude.
