Any successful experiences with Rancilio Silvia 2009?
Link to "Any successful experiences with Rancilio Silvia 2009?"by cksaurus on Fri Jun 12, 2009 6:06 am
Hi there,
I have espresso making experience for about a year and just purchased the new Rancilio Silvia 2009. Together with the earlier bought Rocky, I am able to make much better espresso and latte than before when still using Saeco Aroma. However, I am not very satisfied with the taste of espresso made and the microfoam made. After having an extensive research on the web, I found most of the opinions were made around the old Silvia. Hence, I want to seek advice from those who have successful experiences with Silvia v3.
Here is my espresso making routine :
1. Turn Silvia on for an hour (or use Mark Prince's cheat Silvia trick) to heat up.
2. Grind, dose and distribute using Stockfleth's move. Rocky grind level 7.
3. Tamp with Espro clicking convex tamper, which is calibrated for 30lb.
4. Cool flush and reverse temp surf. I have tried, not systematically, the following time to pull the shot in 25 sec :
1:30 min -- too bitter
60 sec -- a little bitter
50 sec -- better
I have to say that I don't know if I've tried any nicely made espresso so got no idea if the taste is okay. But the crema is not like what the others say being 50% of the shot. There is a layer of crema on top but that's it. I already use pretty fresh beans, roasted for about 2 weeks. The roaster runs his own cafe and makes really lovely coffee.
When it comes to milk frothing, after bleeding the steam wand twice, I can make okay foam after changing from a bell shaped pitcher to a straight walled one (600ml). But the bottom part is always hot milk so when I pour, the hot milk comes out first and make the rosetta look like a withered one. I find the 3 hole steam tip difficult to use and it is not easy to maintain the whirlpool in the pitcher as the holes burst steam in 3 different directions.
Any advice is much appreciated.
Thanks!
In search of excellent espresso
cksaurus
Link to "Any successful experiences with Rancilio Silvia 2009?"by HB on Fri Jun 12, 2009 7:08 am
cksaurus wrote:However, I am not very satisfied with the taste of espresso made and the microfoam made. After having an extensive research on the web, I found most of the opinions were made around the old Silvia. Hence, I want to seek advice from those who have successful experiences with Silvia v3.
The changes were mostly cosmetic: fancy driptray, steam knob, portafilter handle. The only functional difference I recall is an adjustable over-pressure valve, which is to say the mountains of advice and videos dating back for years should be applicable to your 2009 model.
Mark's video as part of CoffeeGeek's updated First Look.
cksaurus wrote:I have to say that I don't know if I've tried any nicely made espresso so got no idea if the taste is okay. But the crema is not like what the others say being 50% of the shot. There is a layer of crema on top but that's it. I already use pretty fresh beans, roasted for about 2 weeks. The roaster runs his own cafe and makes really lovely coffee.
Just a guess, but you might try lowering the brew pressure. A lot of espresso machines ship with the pressure set to ESE pod standards (11 bar). Reducing the brew pressure to around 8.5 bar will reduce bitterness and the likelihood of channeling.
cksaurus wrote:But the bottom part is always hot milk so when I pour, the hot milk comes out first and make the rosetta look like a withered one.
It doesn't look bad, but if you post a video of your routine, I will try to offer specific suggestions.
Link to "Any successful experiences with Rancilio Silvia 2009?"by Gus on Fri Jun 12, 2009 9:33 am
If you just made the switch to the Silvia in the past few days I would not worry about the milk too much yet. I have used 4 machines and each machine required a slightly different technique. Each time I got a new machine it would take a couple of days to get used to the steaming characteristics in order to achieve a good texture. In the end they all produced latte art foam. Some were better some were faster, but they were all capable. I have never used a Silvia, but I did have a Silvia wand attached to my Gaggia Classic and it produced very nice milk, the best of all the configurations I had tried up to that point.
Gus
Insert catchy phrase of choice here
Gus
Link to "Any successful experiences with Rancilio Silvia 2009?"by D.Sweet on Fri Jun 12, 2009 1:26 pm
I would agree with HB and say that you should try adjusting the OPV down almost a full turn. Or it would be better to make a sort of pressure gauge to find exactly what your particular machine is running at.
I also feel that your wait time for your reverse temp surfing may be a bit long. But you might have come to this conclusion already looking at the data you posted.
It depends on too many factors to list, but if you are running a cooling flush longer then 1 second the boiler temp can drop rather rapidly. I have been doing two pulse cooling flushes of about 1 second (maybe slightly more). Lock my portafilter, wait roughly 30 seconds, and pull.
I have a hard time telling between bitter flavors of high temp shots, and sour flavors of low temp shots so i am by no means an expert on Miss Silvia. I just got my PID in the mail, and hopefully i can refine both my tastes, and my shots.
I have an older model Silvia and had similar problems frothing milk with her in the begining. I am now using a straight walled, slightly tappered pitcher, and have minimal problems. I still get a little bit of milk at the bottom of the pitcher, but i attribute this to letting the pitcher rest for a minute while i wipe the thermometer down.
-Donovan
D.Sweet
Link to "Any successful experiences with Rancilio Silvia 2009?"by thefly on Fri Jun 12, 2009 2:51 pm
I would strongly suggest getting or making a pressure gauge before fiddling with the OPV. Older Silvia's OPV's were set at 11 but more recently the pressure has been set lower so 1 full turn would be too much. My is a 2008 model - about a month old (picked up on sale as '09 models were now available).
My OPV was set around 10. IIRC the OPV nut is 6 sided - I turned mine down 3.5 sides (just over 1 half of a full revolution) to get the OPV to 8.6 BAR with water running.
If you are using a blind pressure gauge (easier to assemble) then set it to get 9.0 BAR. With water flowing there is an approximate decrease in pressure of 0.4 BAR.
thefly
Link to "Any successful experiences with Rancilio Silvia 2009?"by cksaurus on Sat Jun 13, 2009 3:45 am
Thanks all of you for sharing your experiences!
I am thinking of changing the brew pressure but am a bit hesitant since the Silvia user guide does not depict the process clearly. Is there any webpage with photos showing how this can be done step by step?
The cool flush I made to Silvia goes on until the boiler light turns on again. Then I wait until it is off and start counting the time. Perhaps I should try pulse cooling flushes and wait for a shorter time and see what happens.
The new Silvia steam wand has 3 holes which makes the milk frothing too fast to get good microfoam. Maybe I put the tip in the wrong position but it is quite difficult to master than those with one hole tip. The hot milk at the bottom usually amounts to about 1/3 of the pitcher. I guess I should further hone my skill at this.
I will post a video later to show my routine.
cksaurus
Link to "Any successful experiences with Rancilio Silvia 2009?"by blueface on Sat Jun 13, 2009 5:00 am
Sorry to hijack your track. I got mine a few days back and I noticed that there're 2 water tubes in the water tank. Why 2? 1 is longer than the other but the funny thing is that 1 is with a V cut at the end and the other shorter 1 is without. Why so? Care to enlighten? :D
blueface
Link to "Any successful experiences with Rancilio Silvia 2009?"by HB on Sat Jun 13, 2009 8:26 am
One tube is the pump inlet (V), the other is the return from the over-pressure valve. For the longer answer, see Adjusting brew pressure of vibe pump, Vibe pump's OPV (over-pressure valves) explained and I still don't get it: Why adjust the OPV?
Link to "Any successful experiences with Rancilio Silvia 2009?"by blueface on Sat Jun 13, 2009 9:12 am
HB wrote:One tube is the pump inlet (V), the other is the return from the over-pressure valve. For the longer answer, see Adjusting brew pressure of vibe pump, Vibe pump's OPV (over-pressure valves) explained and I still don't get it: Why adjust the OPV?
That means to say the other tube without the "V" cutting (return from OPV) can be left above the water level, right?
blueface
Link to "Any successful experiences with Rancilio Silvia 2009?"by HB on Sat Jun 13, 2009 10:59 am
Right.
Link to "Any successful experiences with Rancilio Silvia 2009?"by TheJohnNewton on Sat Jun 13, 2009 11:06 am
I know some more skilled and patient than I have success with temp surfing but IMO a PID really should be a standard part of a Silvia.
TheJohnNewton
Link to "Any successful experiences with Rancilio Silvia 2009?"by andrewpetre on Sat Jun 13, 2009 12:16 pm
+1 PID. With knowledgeable people talking about significant discernable differences in (coffee taste) output from 198-203, How can anyone expect to guess-surf their way to success? Maybe if you can find blends that are far less sensitive to the temperature changes?
andrewpetre
Link to "Any successful experiences with Rancilio Silvia 2009?"by HB on Sat Jun 13, 2009 1:42 pm
-1 PID.
It's a pity the 2009 model doesn't address Silvia's Achille's Heel - poor brew temperature control. Instead Rancilio increased the price for largely cosmetic improvements. While I understand the desired price point makes a stock PID too costly, there are surely better thermostats / solutions than its el-cheapo stock one.
Link to "Any successful experiences with Rancilio Silvia 2009?"by blueface on Sun Jun 14, 2009 4:32 am
To Rancilio Silvia's owner, is there a time limit for the steam switch to left in the ON position?
blueface
Link to "Any successful experiences with Rancilio Silvia 2009?"by TheJohnNewton on Sun Jun 14, 2009 12:44 pm
Dan - Better temp control via a better thermostat would certainly be an improvement. Being able to actually set the temp to my liking though has completely changed the machine for the better IMO. Night and day for me. Like I said above this may not be as big a factor for those with more skill than I but for me it made the machine usable. If they could add a PID from the factory and sell it for a price that would be viable I have no idea.
TheJohnNewton
Link to "Any successful experiences with Rancilio Silvia 2009?"by HB on Sun Jun 14, 2009 8:07 pm
blueface wrote:...is there a time limit for the steam switch to left in the ON position?
As long as the heating element is covered, no problem.
TheJohnNewton wrote:Like I said above this may not be as big a factor for those with more skill than I but for me it made the machine usable.
No doubt that's true.
As an aside, to my knowledge, owners of espresso machines like the Gaggia Classic and Solis SL70 aren't clamoring for PID control like so many Rancilio Silvia owners do. As a forum observer, it appears to me they also suffer far less difficulty learning how to use them. Despite this and their lower cost, the Rancilio Silvia seems more popular. I understood why years ago when it was priced competitively, but today? I don't get it.
Link to "Any successful experiences with Rancilio Silvia 2009?"by blueface on Sun Jun 14, 2009 9:03 pm
HB wrote:As long as the heating element is covered, no problem.
What do you mean? Can be more specific? Thks.
blueface
Link to "Any successful experiences with Rancilio Silvia 2009?"by HB on Sun Jun 14, 2009 9:05 pm
Er, the boiler doesn't refill automatically?
Link to "Any successful experiences with Rancilio Silvia 2009?"by blueface on Sun Jun 14, 2009 9:16 pm
HB wrote:Er, the boiler doesn't refill automatically?
By normal operation, should automatically refill right? If yes, not a problem to leave it ON for a longer period due to steaming a few pitchers of milk right?
blueface
Link to "Any successful experiences with Rancilio Silvia 2009?"by cksaurus on Sun Jun 14, 2009 9:28 pm
Looks like the discussion now has diverted from its original topic. Perhaps I should start a new one and make a more specific title for a more focused discussion.
cksaurus
Next
Return to Tips and Techniques
