nixter wrote:I was just going back over this thread and found this post. So strange that we get such different results from supposedly identical machines. Your pstat is set to 1.1bar correct? What temp do you idle at?
yes i set it to 1.1. it idles around 204-206.
i did do some flush-n-go readings. stopped the flush at 206 then pulled. thermofilter read 199 at the top of the shot then 191 at the end.
i imagine having it plumbed or tanked has a lot to do with it. the water coming in to my machine is currently 57F so i would figure it takes longer to warm up vs. the 80F water in the tank.
i will run some readings on tank mode.
