HB wrote:Actually both systems (HX and dual boiler) are under some pressure due to thermal expansion. You'll notice that the brew gauge on HX E61 lever-type espresso machines will read zero immediately after a shot and then slowly creep upward. Brewtus doesn't have a brew gauge, but it should behave similarly. This residual pressure can push out some water at the mid-way position, but not enough to preinfuse per se ("partially wet the top of the puck" is more accurate).
1/2 to 1 ounce of water (try it with a measuring cup). A double puck requires a little over an ounce to soak. If I'd known then about this, I wouldn't have wasted a week on "pre-pre-infuse" experiments on my Tea when I got it.
