King Seven wrote:I think with blends created by roasters with a brew recipe in mind then it is unlikely you are going to vastly improve the quality of the shot by straying a long way from those parameters (with the obvious caveat that the roaster understands how to brew espresso properly - but that is a whole other thing).
The whole dose thing becomes a lot more interesting you are perhaps roasting coffee yourself and you have no fixed style in mind for how you want to brew the espresso. It becomes something of a chicken/egg thing - do you tailor the profile of your roast to taste good at a certain dose, or do you tailor your dose to get the best out of your roast or do you try both extensively and see which gives you the best possible shot (and likely a quite horrific caffeine comedown). Roast profiles have such a huge effect on not only the flavours given up by the raw materials, but also in the way that it gives them up, that I think it is difficult to speak in absolutes about dose vs. origin/process.
There is a simpler way. Now, it does happen to be the way that I do things, which might disqualify it in the eyes of some
That is to forget entirely about blending and related issues, and to concentrate on the few coffees that can stand on their own, for espresso, as single origins. To my knowledge, few of these will benefit from "updosing," so one can pick a middling dose (which I've suggested many times before as being in the neighborhood of 14g). With this dosing and approach, which means you will use mostly dry processed African coffees, especially those from Yemen and Ethiopia (although the majority of dry processed Africans will prove unsuitable, so you can't just pick any of them randomly), you will want to roast to a little bit before the onset of 2nd crack. Simplicity defined.
For those other potentially usable SOs, you will likely have to tinker with the roast level (probably darker for a suitable Latin American wet processed coffee), but probably not with the dose.
Little basket preparation will be needed, you just have to get the grind right.
Little caffeine overdose will result.
This approach gives you the opportunity to see what different individual coffees actually taste like, not-camouflaged by the other coffees in a blend. And you can have a little private chuckle reading threads like this about how people jump through all sorts of hoops, to get results that are likely inferior to what you can get with so little effort
ken
