by Junior on Fri Sep 11, 2009 3:55 pm
As a relative new-comer to this, I can use some tips on knowing how to gauge temperature flaws and what to do about them. I'll start with what I (think I) know: too cold of an extraction tends to taste sour, too hot is bitter.
I use a cimbali jr.- a fairly stable hx. I've adjusted the pstat to approximately 1.1 bar and follow a fairly simple flush routine which yields a consistent result. I'm not so concerned about a thermometer read out, as I would prefer getting a better handle on tasting a flaw and how to correct it (or at least how to approach correcting it).
Here's what prompts my questions. I started with a triple basket on my machine since it lacked a stock basket. When I switched to a double basket, I noticed immediate improvements in channeling, but fairly bitter extractions with most blends and decaf's but pretty good balance from most SOs, in particular a brazil ipanema with a light roast seem spot on. A very long flush regime helped but did not cure the bitterness/balance issues with blends and darker roasts. Since the triple basket did not have as much of an issue with bitterness, I figured the larger dose or basket must in some way compensate for a higher temperature of water, so I updosed in the double, which helped some with bitterness, though this presents other issues with my machine which doesn't behave well with updosing (probably since the screen protrudes into the basket fairly far without clearance below the dispersion block).
a) am I looking at this correctly as a temperature issue?
b) is there another way to account for cooler water besides a longer flush which I've been doing (or adjusting the pstat when I change coffees) and/or updosing, changing baskets?
c) is it better to adjust the pstat lower and change the flush regimes to attempt to cover both the darker roast/blends and lighter roast SOs?
Michael
