As I was battling my chronic channeling/early blonding and bitter/sour (tannic?) problems again this morning, the technique described in this thread came to mind. I gave it a try, and while it didn't fix my problems, I did notice a subtle difference visually. The slick stainless bottom of a tamper isn't really that grippy though, so it probably won't do much to fix a fundamentally flawed distribution from the grinder. For that, there's WDT, nutation, etc.
None of those have gotten me where I'd like to be though, and I probably need to solicit some semi-professional training. Starting with a mound of coffee in the basket, simply leveling with the weight of the tamper as many have recently suggested results in serious donut extractions. Tightening the grind enough to eliminate that results in a nearly choked extraction. WDT doesn't seem to help much. I've had the most luck with nutation, but even that isn't immune to channeling.
However, while also thinking about this simple twisting technique and the latest cutting edge consensus that tamping really isn't that important, I started to wonder about alternative tamper surfaces. My uneducated theory is that denser areas of the puck compress less and act as a load-bearing pillar that "protects" the less dense areas during tamping, which then open up as fissures during extraction. I'm imagining a tamper with ~.5-1mm grooves cut into its bottom surface, spiraling outward from the center (not unlike the cutting pattern of flat burrs). This surface would be set gently on the mound and spun with nothing more than its own weight. This surface would exert more force on higher/denser spots, and grounds there would be forced into the grooves. Through backpressure in the grooves, these grounds would be deposited into lower/less dense areas, where less pressure exists against the surface. After a few revolutions, the force applied from each point on the bed of coffee to the tamper will reach equilibrium, and the migration of grounds would stop. The tamper will have settled as these pillars of grounds are torn down and relocated, hopefully resulting in optimal (and
perfectly repeatable) distribution. The grooves would still be filled with a negligible amount of wasted coffee, but would create a flat surface and effectively polish the puck.
Unfortunately, this is a theory from someone with no background in materials/fluids/mechanics/etc, and also from someone with zero metal-working equipment or spare tampers to test this hypothesis. I guess that doesn't mean it's not an idea worth entertaining. Thoughts?
Edit: this is unrelated to VST baskets. Too far off topic for this thread?
Split from New dose/distribute/tamp technique for VST? by moderator
