by trihard on Thu Apr 14, 2011 12:32 pm
Hi,
I am a relative beginner in the home Espresso world, and I am trying to alter the dose of Espresso I use per the advice on the top of this forum to get a better tasting shot. My question is on technique. From what I was taught when I learned to make Espresso, I fill my PF till it overflows, then used the N-S-E-W technique to flatten it at the top, then I tamp to 30lbs. Then, I see the time that requires for me to get my shot (hopefully between 20-30 secs) and then alter the grind to get it in this range. Ok, but what if I want to alter it to get a better taste?
The question is, if I want to increase or decrease the dose, how do you go about filling the PF? If I want to increase the dose and I am already overflowing the PF to do the N-S-E-W thing how do you go about putting more in there? Likewise, if you want to decrease the dose enough, you might not even have enough to fill the PF to the top level.
Thanks in advance!
