by cannonfodder on Fri Apr 15, 2011 9:00 am
There is no one dose fits all. Dosing below the rim of the basket may be required for the optimal flavour of a particular blend. That is were you need the scale. You can also use different baskets. I have a variety of makes and each one has a different neutral dose (fill to rim and level). If you are trying to jam 20+ grams in a basket you may need to jump to a triple basket. Those deep triple baskets may also require a bottomless portafilter.
