Did some experimentation with 14.5g PR Espresso Nuevo at 200f (226 on the MLG) and some test strips from the pet store.
Tap Water tested out at ~200 hardness and 8.0 pH. Not quite in line with the city test results. Shots with this were way off. There was a bad aftertaste and noticeable astringency. I would not drink this daily.
Brita filtered tap water tested out at ~20 hardness and 7.0 pH. I was surprised the Britta balanced the pH. This makes an ok shot but is what got me looking at my water setup in the first place. Crema and body are weak but its better than the tap water.
Crystal Geyser bottled water tested out at 80-90 hardness and 7.0 pH. Its really amazing how much better the shots taste with this water. Actually, I discovered this by mistake. A few weeks ago my shots of Nuevo were just killer....for about a week. And then things went south. The shots were ok but lacked the body and taste I loved so much. I attributed it to aging coffee but never really believed that. I got another batch of Nuevo but even fresh beans didn't bring back the killer shots. The other night while reading the ILWFaq I remembered that I had run a gallon of CG through the Silvia right before switching to the Brita. If I had understood how truly important water is I probably would not have overlooked this significant change.
I'm not sure what made me happier, the taste of the first shot with the CG back in the tank or the fact that I was actually able to figure out what was wrong and correct it. The icing on the cake was seeing the test strip results totally align with what "should" taste good. Now I need to find a filtration setup that fits behind my refrigerator and can get close to the 90/50 mark.
My new order of importance in espresso making is coffee, grinder, water, barista, machine and everything else. Sadly, I will now have to go back and retry all of those blends I dismissed over the last few months
