Alkalinity and taste - Page 2
Postby Psyd on Mon Aug 18, 2008 2:22 pm
another_jim wrote:A softener is totally wrong for water that is more alkaline than hard... ...Throw out the softener.
Ehm, Jim, the water here in Tucson is both alkaline and very hard, depending on which well you're pulling from. If you don't use a softener here, your boiler becomes a local stalagtite national forest within weeks! ; >
I've rehabbed a one year old steamtoy for a friend that had completely closed off the steamwand with buildup using tap water.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby another_jim on Mon Aug 18, 2008 9:14 pm
Once again:
-- A softener replaces magnesium/calcium with sodium/potassium.
-- The reason the OP's water is more alkaline than hard is because it already has a high sodium content. Softening it will make that worse. Moreover, softening will not reduce the high alkalinity or the overall mineral content
-- Yes, softening will work for preventing scale on such water, but it will make this already dicey tasting water worse, and will exacerbate any corrosion problems.
This water should be treated with reverse osmosis followed by a calcite cartridge.
another_jim
Postby Psyd on Tue Aug 19, 2008 6:09 pm
Ah, OK, this makes more sense to me now. OTOH, I use a softener and have no issues with taste. Maybe ignorance is bliss, and I'm not changing anything that I don't perceive as broke! ; >
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Previous
Return to Tips and Techniques
