Hi Guys,
I have recently been doing a lot of research trying to get the most out of my crappy starbucks barista athena espresso machine and I have leaned a tonne in the process. I first converted my pressurized portafilter to a non-pressurized one by removing the parts that do the pressurizing. After a bit of practice I was able to get shots which were much better. Much thicker and much tastier. This was a success.
Of course I wanted to refine my technique even more so I decided to chop the bottom of the pf off entirely, so that I could see exactly how my shots were extracting. This is when things when a little awry.
I had to set my grinder about 5-6 notches finer then when I had the bottom on the pf (was about at 8, now closer to 2) to get a shot that extracts in 25-30 seconds. This is confusing to me and I cant explain why the shots run so much faster. The opening in the portafilter was about 1 cm in diameter before and now it is the entire diameter of the portafilter, could the 1 cm hole really restrict the flow that significantly?
Anyways I have finally got the shots extracting in 25-30 seconds by grinding much finer, and the look to be extracting fairly evenly, however, they all seem to taste sour. Much more so than before the chop. I have learned some temperature surfing techniques and I have measured the temperature of the water to be within the 200-205 degree range. So I am not sure why they taste sour now with the bottomless portafilter. Maybe the extra metal that I removed was contributing to extra thermal stability?
Please let me know if you have any suggestions. Thanks!
