by Randy G. on Fri Oct 26, 2007 10:41 am
You need to become as obsessive about your espresso as you are about your pizza:
1) Unless the store is roasting on site, or having it delivered on the day it is roasted, your coffee beans are a lot older than 1-1/2 weeks at the end of the bag/can/whatever they come in. You need coffee that can be consumed within two weeks of the ROASTED date. Basic "rule" is that if a coffee says "best if used by..." the beans are probably already stale. I have seen beans packed that way with a date that is nearly a year off! I try not to keep green coffee that long. Since you are in the NY area, there are plenty of shops that roast on site. Find some roasted coffee that is actually fresh. If all else is equal, if the coffee is bad, try another brand of beans. If all else fails, try a can of Illy whole espresso beans. They taste decent for a day or two after opening the can, but still, there are better choices.
2) The grinder is the most important part of the tool equation, and the Maestro was a marginal grinder for espresso when new and working properly. Yours sounds totally unsuitable now that it is broken, and after 4 years of use probably at least a bit worn. If you are not willing to either get and use a quality hand grinder (an older Zass or similar) or a better electric grinder, your efforts are going to be wasted to a great extent no matter what else you do. A good electric grinder, new, will run at least $250 (around that, anyway) and it sounds like that is not going to happen for you at this point. I have made good espresso with a $10 thrift-store espresso machine, but it was paired with a good grinder.
3) The thin coffee even with hard tamping shows that you are having difficulty with distribution. There are resources on this site that can help. If you are not ready to spend the time to learn, you never will... learn. Espresso is not something that you can get good at in a short time. Like any other form of food creation, it is an ongoing quest that takes a lifetime. Seven years ago, almost to the day, I was shipping for my first espresso machine. I am still learning. If you aren't willing to spend the time learning, why should we spend the time teaching you?
4) At this point, I would suggest that you put the espresso machine off to the side and get an Aerobie Aeropress. At about $30 delivered, it is quite affordable, it works great over a wide range of parameters, and your grinder is more than sufficient for that device. If that does not make a good cup for you, then you either need to get a better coffee bean or you just do not like coffee. No, it doesn't make espresso, but it does make good coffee, and good coffee of any type is better than bad espresso.
To be frank and honest, your post reads like a troll. I say that because so many of your problems are those that are faced by someone just starting out in the world of espresso. When i started out I already knew the solutions to most of your difficulties before my first machine arrived. How? I did the research and lots of reading. I suggest you do the same. Otherwise all this time is wasted.
What if I said to you: "I have been making pizza at home for years now and can't seem to find one that tastes good to me. I have tried every frozen pizza I can find, and I cook them fresh-- as soon as they thaw out, but they still all taste like cardboard. What should I do?" That is what your post sounds like to me....
Not trying to be harsh or rude-- just an attempt at being realistic and honest.
