www.ajcoffeeco.com: excellent coffee without compromise
Advise Sought - 2nd Shot Early Blonding Struggles - Page 2
Postby ponti33609 on Fri Jun 24, 2011 10:37 am
TYPICALLY leave Chris' Coffee with boiler pressure set at 1.20-1.25 bar maximum reading. 1.50 bar boiler pressure would produce a steaming demon
Leads to another question then...............does this assist in frothing/steaming milk? You folks will think I am nuts and I have trouble believing after all I have read but I can froth "fat-free" milk with no issues......small micro foam like folks describe here................
ponti33609
Postby Clint Orchuk on Fri Jun 24, 2011 11:02 am
The Andreja Premium I'm using is set to cycle between .9 and 1.1 bar and has no problem steaming milk and it's pulling good shots. When I first started using it, it was set at 1.5 bar maximum and I found that way too hot.
Clint Orchuk
Postby ponti33609 on Fri Jun 24, 2011 11:05 am
Hi Clint - that is an easy adjustment?
Thx,
Bob
ponti33609
Postby ponti33609 on Fri Jun 24, 2011 11:33 am
Call me a liar..........................
this looks good?? No portafilter in it.
Bob
ponti33609
Postby boar_d_laze on Fri Jun 24, 2011 11:38 am
How do the tastes of the first and second pulls compare? If the water is too hot or too cold for the second, you'll taste it as bitterness or sourness respectively.
Do you clean the basket before loading the second shot? The description of your technique has you wiping the basket with a rag before the first shot, but not before the second. A wet basket -- especially one with a few fines around the sides -- can cause channeling. Quite often (usually?), premature blonding is caused by channeling.
How long does the second shot take relative to the first in order to extract the same volume? Everything else being equal, a faster pour could be another indication of channeling.
What do the first and second pucks look like after their respective pours? How do they come out of the pf when you knock them? That is, does one usually hold together while the other breaks up? Does one seem significantly wetter than the other?
If you can at all afford it, you might want to invest in a naked pf, to learn to diagnose and improve your loading and tamping techniques. It's not only worthwhile as a training tool, the naked pf makes for a visually interesting pour.
It's interesting to note that most everyone finds the first shot of the day from a given machine to be the worst. They (the machines, not everyone) seem to need a little warm up before getting their groove on.
Good luck,
BDL
boar_d_laze
Postby ponti33609 on Fri Jun 24, 2011 12:11 pm
Thx BDL
I knock out the first puck, wash under water and then dry/wipe with a paper towel before I refill. Think I was well but who knows....I will pay more attention to that.
The puck for the 2nd is usually wetter/loose where the 1st is nice and dry.
Bob
ponti33609
Postby tekomino on Fri Jun 24, 2011 12:29 pm
Bob, just verifying are you using same basket or different basket for second shot?
Refuse to wing it! http://10000shots.com
tekomino
Postby Clint Orchuk on Fri Jun 24, 2011 12:38 pm
Easy. Pop the cup warmer tray off. You'll see a little rubber plug in the panel under the cup warmer. Pry it out and look down the hole and you'll see the pressurestat. It has a screw in the top. If I remember right, turn it counter clockwise to decrease the pressure.
Clint Orchuk
Postby ponti33609 on Fri Jun 24, 2011 12:46 pm
tekomino wrote:Bob, just verifying are you using same basket or different basket for second shot?
I am using the same basket having been rinsed under water and paper towel dried.
ponti33609
Postby HB on Fri Jun 24, 2011 4:07 pm
A video of both extractions would be helpful.
Early blonding on the second shot points to puck preparation inconsistencies leading to channeling. To confirm, get a 0.1 gram accuracy scale and use the foolproof WDT + Stockfleths Move for Dummies. It's a little OCD but instructive to get two identical baskets and prep them outside of the portafilter (remove the retention clip so they drop in easily). Then you can confirm or refute with certainty if the issue is tied to the first shot/second shot preparation by preparing both at the same time, then having a helper give you one or the other to brew at random.
PreviousNext
Return to Tips and Techniques
