Stephen, remember that the "standards" are merely "guidelines," and that "experience tasting" is irrelevant -- we are not (and cannot) taste
your shots through the internet. Only you can taste them. That's why what is
most important is how your shots taste
to you!I know you are seeking advice -- and that's fine -- but, while listening to advice, you still need to trust your own taste . . .
As long as Vanelli's "checked and adjusted" the machine, it should be fine. The same is true for your SJ with new burrs. You have a great setup, and you don't need to/shouldn't worry about the equipment . . . especially about the 3-way solenoid.
Experiment with the grind; stop the shot on blonding. Taste. Adjust the grind. Repeat.
Cheers,
Jason
