I have a Baratza Vario, and I've noticed something interesting about the interplay between the grind setting, timer and dose weight.
Normally, I dial-in the grind for a particular dose weight (+/- .1g), then set the timer to produce that weight. The Vario is pretty consistent at producing the same weight for a given timer setting, usually within .2g. When the coffee is fresh, a given time setting will produce the target weight several days in a row.
But as the coffee ages, the amount of coffee produced by the Vario at a given time setting changes, as you would expect. For example, yesterday the grind time on my Vario was set to produce 16g. But this morning, at the same grind setting, the grinder produced about 17.2g. I scooped out about 1.2g of coffee and ran the 16g shot. But it was too fast, about 20 seconds. Clearly this was due to aging of the coffee. So I made the grind finer, but kept the timer setting the same. This time the grinder produced about 16.7g of coffee with the previous timer setting. This makes sense: for any given time value, a coarser gind will produce more weight than a finer grind. I pulled a shot, and it was still too fast, 21-22 seconds or so. Then I tightened up the grind so that the resulting dose was 16g. This time the shot ran the same as it did yesterday, around 27 seconds, and it tasted good, comparable to yesterday's shots.
Normally, with any grinder, I would adjust the grind setting until the resulting shot has the desired volume and blonds at about the same time as a good shot produced the previous day. But it appears that instead I can simply adjust the grind to produce a certain weight of coffee at the previously-set timer value, and I'll get very close to the same result.
This was not an isolated event. I've seen the same thing over and over, as the coffee ages: If I adjust the grind to produce the same dose weight as the day before, and keep the timer value constant, the resulting shot volume/time will be the same as or close to the day before.
I'm wondering if this makes sense to the experts. For a given coffee and set of shot parameters, is there a tight enough relationship between the grind and dose weight to be able to adjust grind for a particular weight using a reasonably accurate timed grinder? Something tells me it shouldn't be a linear relationship for all coffees, but the evidence here so far suggests it is.
[Disclaimer: I'm not saying this is the optimum method for determining the correct grind setting, nor am I suggesting that it's better to adjust only the grind (rather than dose, or both) as the coffee ages. I'm simply wondering if this method makes sense from a coffee physics point of view]
