malachi wrote:OK.
You need to flush longer.
If you're only flushing until the water stops sputtering, you're probably brewing at a very high temp. The sputtering is from water at or above boiling temp.
Example...
On the Bricc as I had it set up (1.1BAR) - if I were to flush for a full "5 mississippi" count after the water stopped sputtering, I would be at a brew temp of 200F. In general, almost all espressos are best brewed somewhere between 196F and 203F. Based on what you've said, I would guess that your brew temp is in the 205F-208F range.
In other words... you don't flush until the water stops sputtering, stop the flush and then count "5 mississippi" but rather flush for a "5 mississippi" count after the water stops sputtering.
Does that make sense?
Aaahhh....that makes more sense. I am totally screwing up the flush! I will try some longer flushes (sputtering
PLUS 5 mississippi) and experiment from there.
DavidMLewis wrote:While I don't think this is your problem, I believe you may be able to improve a bit. In my experience of a similar doserless grinder (NS Grinta, heavily modified), I found it quite hard to achieve a really even distribution grinding right into the portafilter and manually trying to fill in the gaps. I've switched to grinding into a small container (the bottom of a Zass Turkish grinder, as it happens), then putting my hand over it and shaking to fully homogenize the grinds and dissipate the static charge. This also allows me to distribute by tapping with my finger on the container as I move it around the basket. The result, at least in my case, has been much more even and much more repeatable.
I will play a bit in this area as well as while I am sure there is a lot of room for improvment, but when I cut the bottom off the PF, that may become more apparent. I do not think this is my problem either in this case though. Keeping beans, grinder, distribution, and tamp constant across 2 machine - going from a PID Silvia (a very unforgiving machine to bad technique, but incredibly temperature accurate with the PID) where the espresso was EXCELLENT to the Bric, resulted in an immediate degradation in espresso taste/quality. I am 99% sure it is the machine...or more accurately, how I am USING the machine that is the problem...hopefully my resolving the total failure to understand cooling flushes properly will fix all...I miss my chocolate bomb cappa's!
Grant
