by BigBlaze on Sun Dec 18, 2011 8:51 pm
Hi,
My new Ascaso iSteel Duo Prof Tronic comes with this 58 mm filter holder. How many grams of coffee should I had?
Is it at my discretion? When I had 2 scoop (the plastic scoop included with the machine from Ascaso, with I suspect is 7 grams a scoop), there is lots of space between the tamp coffee and the top of the filter holder.
Right now, I'm over fill the filter with coffee, and use a flat object, like a knife, to remove the excess coffee.
Is this a good practice? About the grams of quantities use when doing this, I really don't have a clue. Should I worry?
Also when talking about brewing time, if 14 or 16, 18 or 20 grams of coffee is use, does it change the brewing time?
When time the brewing, do you start when you activate the pump or wait for the first drop to come out.
When using more coffee, like 18 grams for example, do you aim for a larger quantities, like 2 ounces?
I'm new to all this and need help for producing good result.
Thank you,
BigBlaze
