24/7 or on for pulls only?
Postby Psyd on Sat Sep 17, 2011 3:56 pm
I've discovered yet another reason to keep the machine on instead of shutting it down between shots:
Sous Vide...
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby Jeff on Sat Sep 17, 2011 8:43 pm
Even funnier as I have to be careful not to have my machine on when a bath is on the same circuit as well.
Jeff
Postby TomC on Sun Sep 18, 2011 2:51 am
Clever, I'll give you that. I'm quite familiar with the concept, just not the exact temps, but I guess that varies depending on the chosen menu.
I have heard about doing sous vide on a rib eye to a temp in that range, vacuum sealed, then quickly seared in the hottest dang cast iron skillet with oil and coarse salt, with pepper added at the very end ( it burns ) and ending up with steak from heaven.
Fresh out of the roaster: SM Ethiopian Yirg Grade 1, Compass Ethiopian Sidama
Next batch: Guatemala Geisha...
TomC
Postby coffee.me on Sun Sep 18, 2011 10:11 am
Psyd wrote:Sous Vide...
...and for months now, worked beautifully for homemade yogurt too.
"Beans before machines" --coffee.me ;-)
coffee.me
Postby germantown rob on Sun Sep 18, 2011 12:36 pm
TomC wrote:Clever, I'll give you that. I'm quite familiar with the concept, just not the exact temps, but I guess that varies depending on the chosen menu.
131f would be good for steaks, for chicken I like 145f for enough hours to kill the bad stuff. BTW my wife says sous vide tenderloin is way to tender, lol.
I am definitely going to check a pot on my cup warmer to check the temp, love it!
germantown rob
Postby TomC on Sun Sep 18, 2011 2:14 pm
And I thought it was going to be another "should I leave it on all day and night" threads that have been hashed over before, even currently. Nice original content :)
If I lived in Vermont, maybe I'd put my syrup on there at night before Saturday morning breakfast!
TomC
Postby germantown rob on Sun Sep 18, 2011 2:24 pm
I saw the honey resting nicely on the tray and thought that was a darn good idea, maple syrup is another good one. Might not have any room for my cups if these ideas keep coming, LOL.
germantown rob
Postby Bushrod on Tue Sep 20, 2011 10:00 am
Wow, I never thought of putting honey on there! Thanks! I have some that could really use the warming.
Rich A
LMWDP #131
Bushrod
Postby yakster on Tue Sep 20, 2011 4:55 pm
I've started cooking steel cut oatmeal in a crock pot overnight. If I had a machine with a drip tray I could leave on, I might measure the temp of the crock pot (on low) and see if this would work.
It would also be fun to put a Stirling Cycle engine or fan on top.
yakster
Postby samster on Fri Sep 23, 2011 6:47 am
to quote Christian Szell: Is it safe?
TomC wrote:... sous vide on a rib eye to a temp in that range ...
samster
Next
Return to Tips and Techniques
