16g in 32g out in 29 seconds...
All sounds good, except it only yields 1 oz...
Do I change grind? Dose? Or both?
- keno
How does it taste? If it tastes good then don't change anything. If it doesn't then you should make changes based on taste.
I drink cappuccino mostly and it tasted fine that way. It was bit bitter for me as an espresso.
Who is the roaster and what do they recommend?
Sound pretty good to me.
- homeburrero
If you are unsure about dose vs grind changes, be sure to check out this FAQ:
Espresso 101: How to Adjust Dose and Grind Setting by Taste
Pat
- keno
In that case you might try to coarsen the grind and updose. What temperature are you pulling at? Alternatively you could try decreasing the temperature.swjeon wrote:I drink cappuccino mostly and it tasted fine that way. It was bit bitter for me as an espresso.
I am using counter culture coffee forty-six that was roasted 6/7/16.
I'll try coarser with 18 gram route first, I have HX machine and still going through Dan's post on HX temp adjustment.
- jchung
I find that my volume for a given weight will change based on the amount of crema. Lots of crema and I get 2oz. less crema and I get 1.5 oz. I'm guessing you don't have a lot of crema in the shot you pulled otherwise you would be closer to 1.5oz instead of 1oz.
I think there are a couple possible reasons for this: 1) beans are getting old, 2) grind is too fine.
You can try grinding a little coarser and updosing. You can try fresher beans.
Beans are 5 days old, I will try coarser with updosing.
Thank you!
Thank you!
Buy refractometer for $100 and know exactly what to do to tune.
