Versalab M3 Grinder - Page 7
Postby AndyS on Tue Aug 09, 2005 8:02 pm
another_jim wrote:I don't want to give anything away until I've racked up about 20 to 30 comparative shots over the next week, but I'd like you to also try some milk drink comparisons if you normally make these.
OK, will do.
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
AndyS
Postby AndyS on Tue Aug 09, 2005 10:25 pm
Abe Carmeli wrote:DAY 4
Today I was trying to determine the optimal Barista technique for the Versalab M3 grinder. Let's see some pictures:
Uneven distribution half way into the grind
The distribution out of the grinder is not always perfect as we see in the image above. (I am nitpicking here, of course). The photo was taken half way into the grind of a 14 grams basket. This does not happen on every grind but on about 50% of them. I found that a good way to fix it is simply to turn the basket or P/F 180 degrees halfway into the grinding session.
Gee, this uneveness hasn't been a problem for me. Hope this isn't a dumb question, but are you sure that you're not simply holding the pf at an angle underneath the exit funnel?
I found that tapping the p/f straight down against the counter, halfway or 3/4 way into the grinding session allows me to control the final dosage amount and still keep even distribution
I cut a piece of 1/4" thick polyethylene about 4" x 5". It lays on the base under the exit funnel. 3/4 of the way through the grind I tap the pf on the plastic to settle the grounds, which sounds exactly like what you're doing.
-AndyS
AndyS
Postby Abe Carmeli on Tue Aug 09, 2005 10:33 pm
AndyS wrote:Gee, this uneveness hasn't been a problem for me. Hope this isn't a dumb question, but are you sure that you're not simply holding the pf at an angle underneath the exit funnel?
No angle. I hold it flat against the funnel exit gasket.
Abe Carmeli
Abe Carmeli
Postby another_jim on Wed Aug 10, 2005 2:28 am
Have you levelled the grinder? Since I found out my Mini sounds smoother when it's level, I've been using shims to make sure the grinders aren't atilt. Maybe a tilt can affect the the M3's distribution.
another_jim
Postby Abe Carmeli on Wed Aug 10, 2005 8:05 am
another_jim wrote:Have you levelled the grinder? Since I found out my Mini sounds smoother when it's level, I've been using shims to make sure the grinders aren't atilt. Maybe a tilt can affect the the M3's distribution.
As a matter of fact no. I'll dig out my level and check it out.
Abe Carmeli
Abe Carmeli
Postby Abe Carmeli on Wed Aug 10, 2005 8:49 am
DAY 5
As of this morning, my M3 died a sudden death. There will be a reception held in my kitchen tomorrow from 4:00 to 6:00 p.m. Coffee will not be served. All well wishers may post their condolences on this thread.
It looks like power supply, but I could be wrong. The good thing about it, I will have the opportunity to checkout Versalab's quality of service. But why so soon, and why me :( ?
Abe Carmeli
Abe Carmeli
Postby cannonfodder on Wed Aug 10, 2005 10:18 am
Ouch, that sucks. Hopefully not a sign of QC problems.
cannonfodder
Postby lennoncs on Wed Aug 10, 2005 11:39 am
Abe,
I do Post_Mortems for Free!
Just send the unused portion (postage paid) to me...
:D
Bummer
could just be teething pains
Sean
lennoncs
Postby another_jim on Wed Aug 10, 2005 2:29 pm
Sorry to hear it, hope you can get it resolved quickly.
another_jim
Postby Abe Carmeli on Wed Aug 10, 2005 4:28 pm
DAY 5 1/2
The Resurrection
The rumors of my grinder's demise have been greatly exaggerated. The cause of the problem: A combination of stone caught between burrs, and a slow blow fuse on the grinder. The Versalab Grinder has a 2amp slow blow fuse that is designed to blow when a stone is caught in between the burrs. I was running my kitchen circuit at maximum load, and my kitchen fuse blew before the grinder fuse could kick in. I need to replace the 2 amp slow blow fuse in the grinder with a 2 amp fast blow.
As to Versalab service, they called me after getting my email, I spoke to John Bicht directly, and through a quick process of deduction he figured it out. They offered to have the grinder shipped back to them for repair at no cost if needed. I spoke to John about the dial scale issue and the dial retention problem, and I will post a separate note about it tomorrow.
Since I had to disassemble the burr set again, I took some more pictures for you burr freaks out there.
Lower Burr Set
Complete Burr Assembly - Side View
Last image captured by many coffee beans on their way down to the belly of the beast
Abe Carmeli
Abe Carmeli
PreviousNext
Return to The Bench
