I have gotten to spend a couple of quality weeks with the Elektra Microcasa Leva and it has been an interesting trip so far. I have always had a thing for Elektra espresso machines, they are simply the best looking machine on the market in my humble opinion. But looks don't make espresso, thankfully they have gotten that part right as well.
The Leva has an exposed brass (which has been plated) boiler that holds around 0.8 liters. The boiler is filled via a hole in the top of the boiler that is located under the brass eagle topped chrome dome. The Leva also has a vacuum breaker located on top of the boiler. Other lever machines have the vacuum breaker integrated in the boiler cap. When the breaker goes bad or starts to stick you must replace the entire boiler cap. On the Elektra you can simply replace the vacuum breaker which appears to be a relatively standard sized breaker available from almost every espresso machine vendor. The boiler dome has 4 holes in it to allow steam to escape be it from the vacuum breaker or dribbles from filling the boiler. That helps prevent the top from rusting.
The Leva is equipped with a glass water level sight glass on the left side of the boiler. The sight glass is also topped with a boiler pressure gauge. You will want to watch your water level while using the machine. The small 0.8 liter boiler will run out of water relatively fast. The water level will also affect the steaming ability of the machine. If you go beyond three quarters full the steam tends to get a little wet. The reduced headspace in the boiler produces a higher velocity steam but with less quantity. A lower water level will provide a higher volume of steam but will less velocity. It is a bit of a balancing act but regardless of the water lever there is ample steam for 6 ounces of milk. More on steaming a little later.
The inner workings of the machine are housed in the base of the machine. Now here is where one of the stand out points of the Elektra. The base of the machine is large when compared to many home lever machines. It measures a full 10 inches across and two and a half inches thick. This provides a very stable platform to work from. Housed inside that base are the adjustable pressurestat and electrical workings of the machine. To gain access to the inner workings you must remove a Phillips head screw which is located under the drip tray, then pull the plastic base off of the pedestal.
That's one of my pet peeves about most lever machines: Why do they insist on putting a screw under the drip tray? Any liquid that gets spilt on the base will end up under that drip tray. Most drip trays on these machines are small, and the drip tray on the Leva is particularly small. You most certainly will overflow it one day. Then all that water will end up under the drip tray. Once there, it will find its way around that screw and into the base of the machine. Once in there, the machine will slowly rust from the inside out. It would be nice if the screw was relocated to a non water prone location, like under the machine or behind the boiler. The other option is to create the base from a non rusting metal like stainless (such as the Gaggia Achille) or giving it a corrosion resistant coating, but I digress.
Included with the Microcasa is a portafilter, double basket, single basket and plastic tamper. The portafilter is 49mm and surprisingly, the tamper is around 49mm as well! The fit is a little loose; I would guess 47-48mm but close enough to work reasonable well. Anyone that has purchased an espresso machine knows how useless most included tampers are, here is a pleasant exception. That made me happy, because I do not have a 49mm tamper in my lineup. The double basket will hold 15 grams of coffee if filled to the top of the rim, I have not measured the single basket.
Now onto the business end of the Microcasa, the group and lever. The Microcasa Leva uses a spring assisted lever. The user must depress the lever to cock the spring and fill the piston chamber with water. Once released the piston will lower under spring pressure and extract your espresso. A caution, don't forget that without coffee in the basket, the lever will raise at an alarming rate. This is a point that the Leva would be happy to remind you of by breaking your jaw or nose when the lever flips up.
The Microcasa heats quickly and requires very little warm-up time. Once the machine has come to temperature, it needs another 3-5 minutes to warm the group and then you are ready to pull your shots. If you get side tracked and leave the machine on for a half hour you will need to turn it off and let it cool for an hour or two. The machine will overheat if left on for an extended period.
The grouphead is bolted directly to the boiler so over time, heat leaches into the group. Since the Elektra requires positive pressure to push water from the boiler to the brew chamber the machine must run at higher than brew temperatures. When the lever is raised the steam pressure in the boiler pushes water into the group. The water is well above the target temperature range of 195-2005F, that is where the mass of the group comes into play. The grouphead acts like a large heat sink and draws heat from the water.
I have played around with dosing in the double basket. I consider the maximum dose to be 15 grams, not because the puck bottoms out against the shower screen but because to go beyond a 15 gram dose you will have fill the basket to the rim, do a partial tamp then add more coffee. As with most espresso machines, there is a sweet spot for dosing and the Elektra is no exception. Now that spot moves depending on the coffee you use, but I find that between 11 and 9 grams are the best target points.
A 10 gram dose is a good starting point and what I usually use when using the double basket. 10 grams is just a little below the rim of the basket. With a little practice, you will be able to dose very accurately based on volume. I can live with that.
Once tamped the basket is around half full.
Now there are as many ways to pull the lever as there are baristas. Some pull down the lever, hold, release, re-cock, release, others pump the lever several times. Me, I just go with one lever stroke with a 4-5 second preinfuse. That gives me a about one ounce of espresso. Now I know that sounds like not much and we are using a double basket, but that is only 10 grams of coffee in that double basket which in on par with a single shot.
I have tried re-cocking the lever but have never gotten any decent results. Even with a very gentle re-cock after the first drops appear I get a poor quality drink. The shot flows fast and goes very blond. I am sure there are others that get good results from a multi pull but I do not. These machines are about quality not quantity and to that end I am perfectly happy with a one ounce drink. If you want larger, than get a pump or a commercial 58mm lever.
Tuesday I got a care package from
Counter Culture Coffee. I received a pound each of the Twin Cities Express, La Forza and Toscano. I decided to heat up the Elektra A3 and pull a shot of the Toscano as a benchmark for tasting. It was a good looking shot but the coffee needed another day or two to degas. So while it looked wonderful, it tasted like baking soda. So a little heads up for others, Toscano needs 5-6 days rest before using it.
So today I made a few fine adjustments to the grind and ran a few shots through the Microcasa Leva. I was getting a nice creamy and nutty cup with a little chocolate in the finish from the Leva. I had to watch my temperature management. If I let the machine heat more than a few moments I started to get a bitter note in the finish from the hot shot. Again, I would lower the lever until water started to flow from the group then lower the lever until it stopped. Then I lock in the portafilter, gently raise the lever and hold the lever for 5 seconds. That allows the piston to fill with water and the puck to partially infuse with water. Then I let go and watch the love come forth.
The shots from the Leva are different. They are lighter in body and crema but brighter and cleaner in taste than most pump machines. The shots tend to be a little paler than those from a pump machine or a manual lever where you can generate more extraction pressure. The cups are more of a press pot/espresso fusion than your typical syrupy shot that a pump machine produces. One is not better than the other, simply different. But if you are thinking of purchasing a Microcasa Leva you may want to keep that in mind.
Frothing with the Leva is very easy. The steam wand is fixed so wherever you position it when you attach it to the valve is where it stays. The steam wand on the right side of the machine and positioned far enough from the boiler to allow sufficient maneuvering room. The steam valve is a quarter turn assembly and uses a plastic knob to prevent it from burning your fingers. The small 4 hole steam tip will easily produce microfoam with just a little practice and the boiler has plenty of steam to froth enough milk for one or two drinks.
I still a little more learning to do but I believe I have a solid grasp of the machine. While the shot volume may be small the quality is good. The cup is very different than most espresso machines so you have to keep that in mind when contemplating a purchase. For a home machine that is tuned to produce three or four espressos at a time (more than that and it overheats) it is a nice machine and a darn good looker.
