r-gordon-7 wrote:Wouldn't having "an outer chamber which then becomes the brew water for the next shot" mean that if you shut the machine down for a while and then come back later you'd have to flush out from that "outer chamber" the now-too-cold water before pulling the first shot? I've not experienced the need to do that on my Pavoni-like Gaggia Factory...
(And, absolutely yes - great thread indeed!)
When I first turn on the machine in the morning, I find my first shot, if I don't flush first, to be too cool. The espresso runs thin and the flavor is bright. The second shot is near perfect with good mouthfeel. The third shot is too hot/bitter and loss of mouthfeel. By the 4th shot, the lever jams. So my first blank shot is only about an ounce so that the next brew water is a mixture of hot and cool water and the final brew water is about right.
Just for more insight into the Pavoni grouphead, the entire head holds about 3 oz, as there is another 1.5 oz in the space above the piston. Therefore with each flush/pull, the grouphead is heated with 3 oz of superheated water, not 1.5 oz. When the lever is raised, the water above the piston is actually pushed back into the boiler (notice that the pressure gauge registers a drop due to a temporary drop in boiler temp) before the inlet hole is uncovered allowing the brew chamber to fill for the shot.
When I make my second espresso (after the blank shot and first espresso), I first proceed to cool the grouphead. I first turn the machine/boiler off. I have a lever rest which I use to hold the lever in the cocked position, but not open all the way. The purpose here is to evacuate the space above the piston. After all, why cool 3 oz of water when you can just cool 1.5 oz. Do the usual wet rag/ice cube bit. Then turn on the boiler and measure the grouphead surface temp to 127 to 135 deg F depending on coffee and ambient temperature, then brew. Repeat as often as needed. It takes me 10 minutes per cup.
