Fullsack wrote:I noticed the test Lusso is one of the "newer" versions. There are some changes that have showed up in the Lussos in the past few months, most notably: the pressure gauge is different, there is more play in the lever and the plastic shield protecting the interior wiring and pressurestat is smaller for easier removal. I am wondering if there are any other differences that might skew the results between the two machines, ie. pre vs. post Millennum La Pavonis. Several contributors to this thread are comparing your Lusso results to their Lusso results.
HB wrote:Greg Scace, creator of the famous thermofilter, plans to machine one specifically for the Lusso. Once it's done, we will create plots of the Lusso's pressure profile with it. I expect it to look like this:
<image>
From Olympia Cremina 2002: The evolution of design
Though I'm not sure about the height of the peaks. The piston is much smaller than the Microcasa, but the spring seems to pack about the same punch. It should put out more brew pressure. I'm not willing to pop THAT spring out of the group, the end isn't a bolt-in like the Microcasa! I'll have to ask Jim if he minds me tapping a hole in the side of the Microcasa's group to plot the brew pressure. I've always wanted to do that...
Dogshot wrote:The PV's group design does not allow for the exchange of water above and below the piston, like the Elektra and Cremina groups do...
Does the water exchange between the top and bottom of the piston change the duration of the negative pressure in the MCaL and Cremina groups, or are all three of these groups similar in the way the upstroke creates negative pressure?
HB wrote:Correction: The Lusso and the Microcasa don't have water above the piston; instead they have a "breather" hole like on a bicycle pump to allow air above the piston to escape during the upstroke.
Dogshot wrote:There's an old thread that has a photo of the inside of the MCaL's group, which clearly shows 3 holes
HB wrote:Sorry, I know the photo you're referring to and it's of my Microcasa (Steve borrowed it for the Elektra/Pavoni side-by-side). There's only two holes. You had me going for a minute... I just removed the piston and rechecked. There's still only two holes.
