default wrote:
regarding the pro's flushing the HX, how would boiler pressure gauge read when it's idle? how would it read after doing such flush? i don't have thermometer install, as other home users, so the gauge reading would give better idea how it goes.
my machine doesn't have a light to tell me when the heating element or the boiler is refilling. so are there any other signs to tell me?
cheers,
I don't flush off boiler gauge readings and don't know of anyone who does in a commercial setting. The gauges are well-known for their lack of accuracy.
You should be able to hear the boiler filling.
If you don't have a heating element light, you can either try to use Dan's method or the idle time method mentioned by Abe or go with the more humanistic old school commerical method of:
1 - flush until autofill start;
2 - grind, dose, distribute, tamp;
3 - extract (taste just for a baseline and for timing);
4 - grind, dose, distribute, tamp;
5 - extract;
6 - taste.
It will probably show signs of brew temp that is too high. So repeat starting with step 4, but this time flush between 4 and 5 for a count of one. If still to high in temp, repeat and flush for a count of two. Etc.
The nice thing about this will be that you'll learn how to use the machine, identify flavours, etc. In addition, in a commercial environment you'll be able to identify what the flush is when busy as a baseline and from that you can adjust longer for slower times.
Not very scientific - but if you want science you can start with Dan's model or Abe's model (just be aware that these will give you a starting point but that you'll need to adjust from it for most commercial machine and commercial volume).
