Dalla Corte Mini OPV:
Mini-Vivaldi OPV:
Endo wrote:Can someone comment on what affect this might have?
Endo wrote:From what I read in the article below, the Dalla Corte Mini OPV (plastic fluidotech) is the cheapest of the lot and would struggle to achieve lower pressures:
http://coffeetime.wdfiles.com/loc...alve/OPV_Valve.pdf
I'm surprised they are using it on this expensive machine when it has already been replaced on the cheaper Expobars.
HB wrote:Expobars have had the same OPV for years. Judging from the Expobar Brewtus III, they recently switched to one that looks similar, but has a metal adjustment screw instead of nylon. The one you pictured on the Vivaldi is also on the Quickmill and a host of other espresso machines. It's less finicky to adjust and looks more sturdy; I have no data to claim one is more or less reliable than the other.
