Well, as Jim is finally getting his Dalla Corte Mini, my testing is winding down to make room for another machine. More to come
I have to say I really enjoyed using the Mini. It is a great espresso machine for the home enthusiast and I was able to push through a ton (literally) of coffee and enjoyed some super espresso.
On the plus side, you can't find a machine with much better temperature control than this one for the money. A quick warm up shot and you are ready to go with a nice flat profile that keeps up with even the most enthusiastic home barista. Steaming is a piece of cake and you will never run out. The machine is compact, well made and straight forward to work on with solid components throughout. Changing temperature is simple and a real treat when playing around with a variety of coffees. Programming for preinfusion and volumetric dosing is easy. Espresso from this machine is as good as I have had from a variety of home/semi commercial machines. Perhaps, if pushed, I would say it has a little less clarity than some of the high end commercial machines I have used, but they are in a different league. Again I say "if pushed" since I have not done a blind tasting between these machines. Perhaps Jim can dig deeper into this.
On the negative side-- and I'm being picky here --I would still like to see a hot water tap. I realize some people won't miss it but I personally use this for water for my press pots and hot drinks and would miss it on my home machine. I would like to see better articulation in the steam wand. I angle the wand into the milk and the Dalla Corte Mini only allows me a 90 degree attack at best. I also use larger pitchers sometimes for bigger groups. It would be nice if the back plate was a bit further back from the group because the portafilter does scratch the back plate being so close to the group. I would love to see a better way of preinfusion that gets deeper puck diffusion before the pump kicks in. My testing on preinfusion with the La Spaziale definitely showed improvement with deeper saturation.
All in all this is another great double boiler espresso machine to hit the home/semi commercial market. If you are looking for a small compact pour over that can make great espresso with plenty of steam for cappuccinos, then the Dalla Corte Mini should be on your list of considerations.
Cheers
Ian
