woodchuck wrote:Also Marshall does your machine have the new graphics? Was there much change from the unit I have?
Not your pro-level photography, Ian, but here it is:
Endo wrote:At least they got rid of the "proof of taste" stamped on the front. Is there some reason they don't just put a "Dalla Corte" logo on the front of the drip tray (or the name of his daughter...
woodchuck wrote: Anyone have a 54mm bottomless pf they want to lend me
The vibe pump is noisy. I have learned to love the rotary so this is a small con for me. Taste wise I don't think there is a whole lot of difference between vibes or rotaries. But it is noisier. Perhaps some more damping would help.
Cheers
Ian
hperry wrote:Once I found that the machine actively resisted overdosing (you can't lock the portafilter) I settled in with 14 to 15 gram dosing and found that I could get very good shots. The Dalla Corte sort of forces you to follow Ken Fox's prescription for dosing.
Martin wrote:Interesting. I grind by dose. Mid-17g for doubles then level by finger to close to 16 or just under and tamp. But not close to 14. This allows me to lock (obviously) but still feel some pressure. I like this "full" (but not over-- ?) dose because I can grind a shade courser. Our different estimates on dose-by-weight might be accounted for by variations in basket size or . . .? I'd like to hear from others on this weight for doubles.
Endo wrote:At least they got rid of the "proof of taste" stamped on the front. Is there some reason they don't just put a "Dalla Corte" logo on the front of the drip tray (or the name of his daughter...).
