HB wrote:The thermofilter's flow rate is faster than 60mls in 25 seconds, so I cannot plot the curve on that timescale. I can create an over-the-lip plot, but I don't think they're comparable across machines, other than to say "the temperature for both machines move in direction X when I do Y".
Let's say we were intending a 26-second pull at a target temperature of 202°F with the pressure at factory setting or lowered to 1.0 as you have done, to prevent a really high spike. Judging from your graph at either pressure setting, for the first half of the pull, the water is below desired temperature and for the second half the water is above desired temperature. Not sure from your data how high the temperature would be at 26 seconds since the graph cuts off at 17 seconds. The flow rate of your thermofilter's pseudopuck coincides with the minimum number of seconds a shot needs to qualify as espresso according to the standard definition.
Can we infer from the Achille's rising intra-shot temperature profile that the designers intended users to pull shots in relatively shorter time with the Achille?
Or do we infer that the designers considered
average temperature over the duration of the shot the important consideration?
Potential purchasers would benefit from temperature plot that extended out to the deep end of the standard definition of espresso, i.e. 26 seconds, and it would be a valuable objective addition to a thorough Bench Review. If the themofilter cannot do it, over-the-lip would suffice. At factory setting and at 1.0, to complement the existing chart would be ideal.
The plot wouldn't be used to compare dissimilar machines, but it would give users a sense of the Achille's intra-shot temperature span at both ends of the espresso shot-time spectrum.
Regards
Timo
