by TRH on Mon Mar 30, 2009 10:33 pm
Ian,
What size holes are in the tips you are using?
On my B1, the single hole is around 1.4 mm (1.54 MM^2).
I also have a gold pro tip that comes with two 1.0 mm holes (1.57 mm^2).
I drilled an additional 1.0 mm between them for a total area of 2.36 mm^2.
With a 975 watt heater element, my B1 will maintain around 1.15 bar with the single tip.
Using the three hole tip drops pressure to around 0.9 to 0.7 bar by around 30 seconds and continues to hover around 0.7 bar till the auto fill kicks in around 50 seconds and knocks the pressure further down to 0.55 bar.
Terry Hendricks
