Michal wrote:My Brewtus also came with a boiler pressure that was set too high.... On my particular unit there was NO WAY to turn that screw without some sort of 90 degree screwdriver.
Assuming you refer to the same comment in your e-mail, you mean the brew pressure. Since your espresso machine is a rotary and it's plumbed-in, the pump's input pressure affects its output pressure. Expobar/WholeLatteLove can't accurately set the brew pressure for you unless they dictate a precise inlet pressure. The difficulty you reported adjusting the pump bypass valve prompted me to ask Ian to photograph it (below). He said it was tight quarters, but was able to adjust the pump in situ.
