Bob Barraza wrote:Once the brew water hits the coffee in the basket, it is hard for me to see how it could continue any laminar characteristics. To me, it seems that diffusion would better describe the process. In either case, channeling is the enemy.
I did a literature search on "laminar flow through aggregates." The term is commonly used in fluid bed heating, serum blood flow through platelets and white cells, and coffee percolation. I think you may be right that it is used analogically, basically to describe a straightline path of the flowing medium through the aggregate. Mostly the concern is about energy, when you get channeling and counterflows, more energy is required (the serum literature was about plaque roughened arterial walls causing serum turbulence). In instant coffee making, the concern is also about turbulent flow decreasing extraction quality.
I don't recall the exact numbers, but during the extraction we are removing between 10-15% of solids by weight. Regardless of the exact number, as we dissolve material from the ground coffee during the extraction we are increasing the porosity of the grounds and the coffee bed. If the pressure is kept constant, the reduced back pressure will increase the flow rate. This will increase the chances of channeling and probably lead to over-extraction.
The coffee cake is apparently complicated (according to Petracci in the Illy book), since the fines migrate during the shot, and create an interlocked, nearly water proof aggregate. This process counteracts the reducing mass of the puck. In any case, different baskets will deliver different rates of flow increase on the same machine (LM double baskets are more even compared to Faema style ones)
Perhaps the ideal machine will not only control pressure but flow rate as well.
Andy has set up his experimental pressure controller to profiles that even out flow. The required pressure drop is far less for pump machines than found on levers. This may be a function of the water path.
