O ring size in 1/4" double fitting (Nuova Simonelli Oscar)
elChupaKen
#1: Post by elChupaKen »
So I narrowed down a small leak coming from my double fitting, and I replaced the O ring that buts up against the valve body the double fitting screws into, but seems like I need to replace some of the O rings within the double fitting itself, which is a bit smaller that the O ring I just replaced. Anyone know the exact size of those smaller O rings within the double fitting itself?
Much appreciated!
