Is my Baratza Preciso's adjustment ring broken?
dkny3939
Postby dkny3939 » Oct 11, 2012, 8:04 pm
Grinder has been behaving strangely, incapable of grinding fine enough for espresso. I took it apart, and found that the little screw that held the calibration in place was the only thing holding the two parts of the adjustment ring together (the part with the micro-adjustment level + the part that goes on top with the hopper teeth). As a result, when I press down on it, the adjustment ring had some flex. Is the adjustment ring bad?
