Hopper that NEVER runs out of beans!
Vakse Viggo
Postby Vakse Viggo » May 18, 2017, 3:12 pm
I really like the look of a full hopper...especially on an old vintage model with glass hopper. I use my 1983 Quickmill Omre together with my 1956 Faema Faemina, but I always had to take off the hopper, or empty it, when using the Faemina.
With this little simple mod it always looks full with old decoration beans, and it does not matter if I accidentally touch the release lever...yes, it happens more often than you think. :) Also the chances of me breaking it, gets smaller...after all, a replacement cost 400 Euro.
Really happy how this turned out.
The doser plastic had seen better days, so a heat gun and a piece of plexi glass, took care of that.
Admin
Postby HB » May 19, 2017, 7:52 am
Smart idea! And it saves you the trouble of having to clean it for aesthetic reasons. :D Excellent job on the replacement doser lense.
artisan coffee from around the globe
Sponsored by Blazing Bean Roasters - artisan coffee from around the globe
Fierce5
Postby Fierce5 » May 19, 2017, 9:36 am
This is genius! It will also shield your beans from the light if you keep the beans you use (not the fake ones) for few days
Vakse Viggo
Postby Vakse Viggo » May 19, 2017, 4:53 pm
HB wrote:Smart idea! And it saves you the trouble of having to clean it for aesthetic reasons. :D Excellent job on the replacement doser lense.
Thanks Dan
It is such an easy and cheap mod, that works on so many levels.
I have to make another doser lense. This one was kind of, or became, a prototype. I found a tin that fits the shape of the doser a lot better, so next time OD will have to be a little bit bigger, and then the top and bottom of the lense will have to be grinded on the outside, so the ID is going to fit just right.
Otherwise the arms will scrape on the plexi. The original plastic was a lot thinner and could be bend into shape a lot easier, but this 3 mm plexi just looks so much better and glass like. Maybe one day, I will have a proper glass lens made.
Vakse Viggo
Postby Vakse Viggo » May 19, 2017, 4:56 pm
Fierce5 wrote:This is genius! It will also shield your beans from the light if you keep the beans you use (not the fake ones) for few days
Thanks Gabriel
Yes, and now I can also do some single dosing with a full hopper! :D
Fierce5
Postby Fierce5 » May 21, 2017, 10:52 am
Now I have to figure out a way to this to my Mazzer Super Jolly with the mini hopper
Vakse Viggo
Postby Vakse Viggo » May 22, 2017, 6:59 am
Fierce5 wrote:Now I have to figure out a way to this to my Mazzer Super Jolly with the mini hopper
Is it possible to click the finger guard off...?
skilled in the art of grinding
Sponsored by Baratza - skilled in the art of grinding
Fierce5
Postby Fierce5 » May 22, 2017, 8:59 am
Vakse Viggo wrote:Is it possible to click the finger guard off...?
If you mean the umbrella like thing in the hopper then yes, I can have that removed as they are attached with screws. Only issue I'll have to find plugs for the screw holes left behind.
Vakse Viggo
Postby Vakse Viggo » May 22, 2017, 11:50 am
Fierce5 wrote:If you mean the umbrella like thing in the hopper then yes, I can have that removed as they are attached with screws. Only issue I'll have to find plugs for the screw holes left behind.
Just put some foil paper in the holes...you wont be able to see it anyway, because of the beans. :wink:
Fierce5
Postby Fierce5 » May 22, 2017, 2:50 pm
Vakse Viggo wrote:Just put some foil paper in the holes...you wont be able to see it anyway, because of the beans. :wink:
I love that idea! I'll give it a shot and maybe take pictures.
