Any machinist out there
- ash4889
I'm trying to find any machinist on here who works with acrylic and has all the necessary machines for cutting and milling.
- ash4889 (original poster)
- bostonbuzz
PM me. I have access to CNC milling equipment, autocad, etc.
LMWDP #353
Looks like something for which 3d printing would work, would try that before investing in tooling.
LMWDP #483
I have a difficult time with just using a screwdriver...lol
Thanks for all the info guys, I didn't know EazyTamp had a new design
BTW ECM only makes 58MM stands, so it wouldn't work for me.
I also checked on eazy tamp and it's the same ol style they've had, So it's back-to the machinists I go.
I still think everyone for their suggestions anyway
- bluesman
It won't take any custom or special tooling to make this - a lathe and a few ordinary bits will make the basic unit and a vertical mill with an end cutter will make the side slot. But I agree that a 3D printer is probably the easiest and best way to make what you want, unless you want it to be milled from a billet for some reason (e.g. weight). There are several 3D printing shops in Ft Lauderdale, and this is a simple piece to make - it probably wouldn't cost you as much to have it printed as to have it machined.Marcelnl wrote:Looks like something for which 3d printing would work, would try that before investing in tooling.
I thought the EZTamp unit comes in 53mm, which should hold a 51 although it very well might not hold a 49 (I don't know which lever machine you have - I'm not experienced enough to tell from the pic).
