OE 3rd Shot...Group Cooling Heat Sink for Olympia Cremina
Postby orphanespresso on Sun Dec 11, 2011 3:12 am
210 grams of pure heat sucking aluminum. Average group temp reduction of 10 degrees in 2 minutes. Designed for Olympia Cremina but will fit all groups using 49mm baskets.
http://www.orphanespresso.com/OE-3rd-Sh..._4387.html
orphanespresso
Postby SlowRain on Sun Dec 11, 2011 8:57 am
Interesting. The video said it will work with the Millennium Pavonis as well. You mean it'll work with the 49mm and the 51mm groups?
SlowRain
Postby tekomino on Sun Dec 11, 2011 10:25 am
I like it. I had something exactly along these lines in mind. You save me work :D
Refuse to wing it! http://10000shots.com
tekomino
Postby Boldjava on Sun Dec 11, 2011 11:40 am
Let's see -- what else do I want the elves to put into the Christmas bag...
B|Java
Boldjava
Postby sweaner on Sun Dec 11, 2011 3:16 pm
Talk about on a roll!
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby yakster on Sun Dec 11, 2011 3:47 pm
I just bought a full portafilter from OE to do the same thing. I'm interested to know too if it will fit a Millennium La Pavoni / Gaggia Factory group.
yakster
Postby espressme on Sun Dec 11, 2011 7:16 pm
Hi Folks,
If your machine can use a 49mm Espressme portafilter, it will work!
Cheers to All! Merry Christmas. :D
~Richard
richard penney LMWDP #090,
espressme
Postby roadman on Sun Dec 11, 2011 9:53 pm
Very intriguing idea. Love the look of it.
Is there any advantage to using 210g of aluminum over the 250g of cold brass (portafilter plus spout)? Does aluminum reduce the group temperature faster than brass?
roadman
Postby orphanespresso on Mon Dec 12, 2011 1:21 am
Aluminum is a lot cheaper than brass with about the same thermal characteristics, it does not tarnish and Barb likes aluminum.
As far as fitting the millennium/factory..the hangup with fitting the 49mm (pre-mill) Penney pf has more to do with the basket than the ears of the pf. I checked and it fits the millennium group. As with all La Pavoni fitting one has to file the underside of the ears to match the size and angle of that backwards LaP pf...or is it all of the other groups that are backwards? the aluminum construction makes it easy to file...you can use a fingernail file to do it.
orphanespresso
Postby HB on Mon Dec 12, 2011 9:54 am
The 3rd Shot "heat sucker" is an innovative idea, but won't the portafilter be cooling down quite a bit in the 2 minutes it takes to do its thing?
For what it's worth, I have a different approach: I take out the basket retention clip and dose/distribute/tamp the basket out of the portafilter. For the 3rd+ shot, I dunk the portafilter in cold water and then lock it in prior to starting. By the time I'm done futzing with the basket, the portafilter is hot again and the group is at temperature.
Next
Return to Marketplace
