OE 3rd Shot...Group Cooling Heat Sink for Olympia Cremina - Page 2
Postby drgary on Mon Dec 12, 2011 11:41 am
HB wrote:The 3rd Shot "heat sucker" is an innovative idea, but won't the portafilter be cooling down quite a bit in the 2 minutes it takes to do its thing?
For what it's worth, I have a different approach: I take out the basket retention clip and dose/distribute/tamp the basket out of the portafilter. For the 3rd+ shot, I dunk the portafilter in cold water and then lock it in prior to starting. By the time I'm done futzing with the basket, the portafilter is hot again and the group is at temperature.
Dan,
Are you doing this with a bottomless portafilter or a stock one? I've found a stock portafilter has enough thermal mass to do the job on a Millennium Pavoni, but I think Chris (yakster) is finding a bottomless lacks sufficient mass. For the dual-switch pre-Millennium Pavoni (without a PSTAT) I don't even know if a stock portafilter is enough to cool things down that way so that other methods must be used.
LMWDP#308
drgary
Postby HB on Mon Dec 12, 2011 11:51 am
I've done it using two portafilters on the Ponte Vecchio Lusso (cold one stock, hot one bottomless). I've also done it using one portafilter on the Elektra Microcasa -- the heavier brass Richard Penny bottomless portafilter. This in combination with a cold sponge across the grouphead works for me, but I won't claim it's delivering precision brew temperature. My main question was about the cooling of the (stock) portafilter while the 3rd Shot is locked in. Two minutes is a long time out of the grouphead...
Postby tekomino on Mon Dec 12, 2011 12:03 pm
HB wrote:My main question was about the cooling of the (stock) portafilter while the 3rd Shot is locked in. Two minutes is a long time out of the grouphead...
I can share my experience. I cool down the grouphead currently using stock spouted portafilter and pull with bottomless. It takes some time for portafilter, especially bottomless to start drawing heat away from the group. And that time is longer than it takes to pull the shot meaning I did not notice it having any effect even when just luke warm...
You can't realistically expect exact temperature management with these machine anyway (and IMO not needed given quality of espresso they can make) so all you are trying to do is make sure you are in the range and not overheating.
Refuse to wing it! http://10000shots.com
tekomino
Postby yakster on Mon Dec 12, 2011 1:50 pm
With my Gaggia Factory Millennium it's a bit of a challenge to get the temp to the point I want (below the bottom marker on the temperature strip) with the bottomless portafilter that came with the machine. I can do some tricks with cold water soaks of the portafilter handle and locking it into the group to drop the temperature, but even then I've had to resort to using cold rags or ice cubes on occasion. That's why I just picked up a full portafilter handle.
I actually like the idea of having two handles anyway, so that I can lock one into the group to cool it down and prepare my coffee in the bottomless one, otherwise it's a bit of a dance to get the timing to work out right to pull the shot. I had considered replacing the plastic (Bakelite?) handle on the full portafilter with a metal handle if necessary to aid in cooling, but it sounds like that won't be a problem. I'll also be able to split shots now, in the event I have company that wants a straight espresso.
I don't get to play with the new portafilter handle, or the new OE dosing funnel for the Factory, until the Wife gives it to me as a present for the holidays this year.
yakster
Postby IMAWriter on Tue Dec 13, 2011 6:50 pm
espressme wrote:Hi Folks,
If your machine can use a 49mm Espressme portafilter, it will work!
Cheers to All! Merry Christmas. :D
~Richard
Richard, My Cremina has been doing VERY nicely now for 4 years with your PF and tamper.
Merry Christmas.
Regarding this new heat sink, if you froze it, I bet you could lower that group temp in about 30 seconds!
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby Boldjava on Tue Dec 13, 2011 7:07 pm
yakster wrote:...
OK, when was the last time you had a gift that made it to the day on which it was supposed to be opened? Truth, now. <Grins>
B|Java
Boldjava
Postby IMAWriter on Tue Dec 13, 2011 7:12 pm
Forgot to say, a very merry Christmas/Happy Hanukkah to all here.
Be safe, healthy, and prosperous in 2012 and beyond.
RJ
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby tekomino on Wed Dec 14, 2011 9:23 pm
Alright got my heat sucker, er, 3rd shot today. Does it work? It sucks! Heat. Greatly sucks.
I really like this. It is much more effective, faster, than locking in cold portafilter. Group-head temperature is down to the good range in about 2-3 minutes. I kept it in the fridge and on 3rd shot locked it in to bring temperature of the group back to acceptable range. You've got to keep the eye on this sucker or it will over-cool! On 4th shot I just cooled it under cold water and locked it in. Works.
If you are making more than 2 shots on Cremina, you can't beat the utility of this heat sink. You lock it in while you prepare the basket and group-head will be good to go by the time you measured and ground the coffee. Love it.
tekomino
Postby peacecup on Thu Dec 22, 2011 4:56 pm
This is a great idea, and should make pulling consecutive shots on any home lever a lot easier. In the time it takes to dose and tamp the next shot the group should be ready. Look forward to hearing users' experiences.
PC
LMWDP #049
peacecup
Postby yakster on Thu Dec 22, 2011 5:13 pm
Boldjava wrote:OK, when was the last time you had a gift that made it to the day on which it was supposed to be opened? Truth, now. <Grins>
B|Java
I've been a good boy and haven't used the portafilter or dosing funnel after testing it for fit upon arrival.
I probably would have ordered myself an OE 3rd shot instead, had it been available then, but I'm sure I'll find a use beyond cooling the group for the spouted portafilter.
For her part, the Wife gave me specific directions on what she wants, a Nook Color.
Happy holidays, all, and if your lucky enough to find an OE 3rd shot in your stocking, may it suck the heat from your group before your able to dose, grind, distribute, tamp, and lock your portafilter into place.
yakster
PreviousNext
Return to Marketplace
