EP Sproline Foam Knife Steam Tips and Precision Shower Screens - Page 2
Postby cafeIKE on Mon Feb 28, 2011 2:43 pm
Drive time musing :
If designing a screen to improve wetting, probably opt for uniform water volume per cake surface area unit... and then a different screen for singles, doubles, straight baskets, tapered baskets, etc.
cafeIKE
Postby terryz on Mon Feb 28, 2011 7:27 pm
Thank you for your suggestions and opinions, they are duly noted
Terry Z
Espressoparts.com
____________________________________
Much of espresso speculation is faith based.- Michael Teahan 2011
terryz
Postby tekomino on Wed Mar 02, 2011 10:02 am
On another hand, Sproline Foam Knife Steam Tip is killa! With my no-burn steam wand on GS/3 it is now effortless to make micro-foam. It takes some work to make good micro-foam with stock tip and especially with small amounts of milk, but this new tip makes it super easy and if you don't pay attention you generate too much micro-foam :D Ah the extremes.
Sproline Foam Knife Steam Tip recommended!
Refuse to wing it! http://10000shots.com
tekomino
Postby Phaelon56 on Fri Mar 04, 2011 4:11 pm
+1 on the Foam Knife steam tip! It took a few tries and a few pints of milk to figure out the technique - which is different from how milk is steamed with a standard tip. But once I got the technique nailed down (at the rudimentary level - I'm sure I can tweak and improve) I am now consistently getting micro-foam superior to any I've ever achieved before. I use only 1% milk in order to reduce fat intake. I've always found it challenging to get stable long lasting foam from lower fat milks. Not the case with the Foam Knife. Count me as mighty impressed with the product.
Phaelon56
Postby mb514 on Mon Mar 07, 2011 12:53 am
Bought Foam Knife based on Dennis' recommendation (just in time, sold out now)... Have never made milk like this. Finally figured out technique today and was baffled by quality of microfoam. Sat and admired it for some time.
mb514
Postby JonF on Tue Mar 08, 2011 12:26 pm
Greetings! I am not sure where to look for thread sizing on tips, etc. . . If anyone ever has a chance to try the Foam Knife on a La Spaziale Vivaldi S1V1 standard steam arm please let me know! Thanks!!
JonF
Postby Mayhem on Wed Mar 09, 2011 5:26 am
At a whopping $75.49 for a friggin' steam tip it better pour my latte art as well... :shock:
Too much is not enough
Mayhem
Postby laservet on Mon Mar 21, 2011 12:07 pm
I just ordered the new GS3 tip this morning, should have it in a few days and will report back here.
The tech I spoke with prior to placing my order told me the Vortex wasn't appropriate for the GS3 and pointed me to the correct tip. Just curious how this GS3 tip would compare with the Foam Knife 1 and 2 in the GS3. Not curious enough to purchase all three. :D
Question: The GS3 tip appears to aim the steam out laterally. Is this correct? I use the toroid steaming pitchers and the milk rolls nicely with steam that is directed out and downward.
laservet
Postby Peppersass on Mon Mar 21, 2011 7:16 pm
Which of the two Foam Knife tips is correct for the GS/3? If both work, what's the difference between the two?
Dick Green
Peppersass
Postby tekomino on Mon Mar 21, 2011 7:22 pm
I have on mine GS/3 Txpresso Sproline Foam Knife 1 Steam Tip. Rocks!
tekomino
PreviousNext
Return to Marketplace
