Custom Wood for your Espresso Machine - Page 70
- cannonfodder (original poster)
The turning is easy, the magic is in the finish which takes days to apply properly.
- UltramaticOrange
I'll bite. What finish are you using?
If your tiny coffee is so great, then why don't you drink more of it?
A special one that takes days to properly apply and 7-9 coats to build the durable luster. Cannot give away all my trade secrets. I can turn a portafilter in 15 minutes, then I spend 8-9 hours of hands on applying the finish.
- UltramaticOrange
I've been using CA + micromesh. Comparison thoughts?cannonfodder wrote:A special one that takes days to properly apply and 7-9 coats to build the durable luster. Cannot give away all my trade secrets. I can turn a portafilter in 15 minutes, then I spend 8-9 hours of hands on applying the finish.
Built a shave set for my kid, time for him to start shaving. Restored a 100+ year old Wade&Butcher straight razor and put it in some ironwood burl scales with an epoxy resin finish. Pin's are 1/16 brass rod with brass over stainless washers and brass thrust bearings. The brush is ironwood burl as well with a high gloss finish and a 22mm finest badger knot and a Mach3 razor turned in ironwood burl as well. Finished up a knife as well in some left over Ironwood.
Now back to my Ebony work for a Rocket.
